Anyone know PNs or a source for the main coil connectors atop each valve cover? Looking for the PCM side connectors and pins.
this is for the engine harness to ign. coil jumper harness.....connector (body)12102754.....terminal (pin) 12048074.......both 6.0l and 7.0l.....hope this helps
Thanks! This should allow us to go forward.
or try chucking this in google http://www.eficonnection.com/eficonn..._pigtails.aspx
