Originally Posted by
oztracktuning
How much extra fuel would people suggest starting with when using a 75 shot of Nitrous dry. I will be using 1290005 to control it.
The car has already done 11.32/119.8mph NA. I will be spraying after the first 1.0s using a FJO progressive controller. Im not planning on spraying off the line.
Im guessing that the factor is around 1.20 to get enough fuel happening and get the AFRs to around 12.0. Im also planning to pull 4.0 degrees out of the main map. The car already ramps to around 30 deg at 6800rpm.
