Results 1 to 3 of 3
Thread: Problem report: 08 E38, BBL, TCS/AH trouble
    Jan 2008
    Default Problem report: 08 E38, BBL, TCS/AH trouble
    When using BBL on a 08 Z06 E38 I consistently get TCS/AH issues. It looks like it happens when the V2 handshakes with the PCM. Car continues to drive fine but TCS/AH lights are lit up and TCS/AH is fully disabled.
    I do also randomly get this same issue even when not using BBL (e.g., when using my laptop to scan and tune). It seems more prominent when using BBL though.
    Oct 2003
    I had the same problem on my 08 Z06 found the problem was that I connected to the ALDL after the engine was running. Plug into the ALDL before you start the engine and it should be OK.
    08 Z06
    Jan 2008
    Good tip, thanks. That may solve the BBL issue. Now I just need to figure out what's going on that trips TCS/AH when not using BBL...
  1. Error Report.
    By horsehaulin in forum FlashScan V1
    Last Post: June 5th, 2008, 10:59 PM
  2. Wiiiiierd Problem...MAF causing trouble!!!
    By 01Blackerado in forum Gen III V8 Specific
    Last Post: October 2nd, 2007, 06:34 AM
  3. Can anybody confirm that GM map sensor #12580698 will report up to 260kPa?
    By onfire in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 19th, 2006, 04:06 AM
