06 LBZ ECM in 06 LLY
Since the operating systems are different, we can't full flash, and IIRC, you can't just copy an LBZ tune into an 06 LLY OS, will an 06/07 LBZ ECM work in an 06 LLY truck? Obviously, I know the connectors are the same, a VATs relink would have to be done and such, just wondering if there's anything else in the truck that would prevent it from working.
i will have to double check this but i am fairly sure gm recently released a calibration update that was labelled "merge lly and lbz calibration"
here it is
Calibration History for: System
Part Number CVN Bulletin # Description
12616738 C9EA5D7C - U0101, U1301, U0106 DTC Robustness Improvements
12606155 87E2079E - New calibration to reduce potential for setting DTC P2610 when battery is connected.
12604106 92074922 - New calibration combines LBZ and LLY usages.
12606234 666A4BF0 - New calibration to reduce potential for setting DTC P2610 when battery is connected.
12604151 1E1607F9 - New calibration to improve generic scan tool operation.
12605534 8FA514E8 - New calibration to correct DTC P0533 setting in hot conditions when A/C refrigerant pressure is high.
12604207 CB1AD742 - New calibration with improved thermostat diagnostics.
12603682 C1E717C6 - New calibration to correct problem occuring at the assembly plant. Does not address any service issues.
12602663 N/A - System calibration
note this is only the system segment listing for a 2006 lbz using operating system 12604138 which by the way is superseded by operating system 12616698
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
