Results 1 to 2 of 2
Thread: HELP fuel trims and AFR all over the place?
    Member warscout2's Avatar
    Jul 2006
    Default HELP fuel trims and AFR all over the place?
    after i uploaded the custom auto ve tune i did the AFR is all over the place.
    it ran fine before i finished the tune.
    while it was in my tuning mode it ran great?
    so im uploading the tune i have running now / the log file / and the tuning tune
    the tune im running now is called{ "formula auto ve tune finished 01302008" }
    the tune i was using to tune with is called { "formula tuning 0108" }
    the log is called log after tune
    Jan 2007
    Can't tell anything from that log. Needs to be alot longer.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
  1. Why negative fuel trims after autoVE
    Last Post: July 16th, 2010, 11:14 PM
  2. E38 fuel trims
    By minytrker in forum Gen IV V8 Specific
    Last Post: July 2nd, 2010, 02:44 PM
  3. Fuel Trims for 12.5 AFR with LC1
    By bobbycollier in forum General (Petrol, Gas, Ethanol)
    Last Post: February 19th, 2010, 04:25 PM
  4. Long Term fuel Trims..
    By waterbug1999 in forum Gen III V8 Specific
    Last Post: July 25th, 2009, 04:23 PM
  5. Fuel Trims are 0
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 17th, 2007, 04:15 PM
