Results 1 to 6 of 6
Thread: ABS warning on dash
    Lifetime Member hymey's Avatar
    Jan 2008
    Default ABS warning on dash
    I won a VE SS-V with E38.
    I have been blackbox logging tonight with 7.5.3 and latest beta firmware.
    When I connected the V2 flash scan to the PCM a traction control off/ ABS warning flashed on the dash of the vehicle.
    I disconnected the cable but it the ABS warning light still flashes.
    I guess I need to reset my computer to clear the warning.
    No error codes appeared in the log. Other than that it all went fine.
    Has anyone experienced this..?
    Joel
    Joel, welcome to thew forum...
    You can get the EFILive scantool to read the ABS DTC so you can get some idea what it's trying to tell you; it may or may not be releated to connecting the scantool to the bus, or it may be a real problem that just coincidentally happened to occur just then...
    in the scantool (using a PC/laptop):
    - go Edit->Properties->Advanced and checkmark Check/Clear DTCs for All Modules;
    - you may also have to go Edit->Properties->Options and checkmark Active Module Detection (if the ABS problem is persistent, the DTC will show up again even if the ABS module is reset);
    then connect to vehicle and go Info->Diagnostic Trouble Codes and the scantool should read all the DTCs for all modules on the bus.
    Joe
    Dec 2007
    Sometimes when I connect the FlashScan to my car it turns on the PassLock? MIL on my dash. (Icon of car with a lock on it.) Once it's on the only way to turn it off is to turn off the car, remove the key, and open the driver door.
    Any chance the FlashScan could change the passkeyIII key resistance from loading the system?
    Last night the FlashScan just shut off when I was displaying pids and it reset my ECU too. All the gauges blinked off and went to zero for a second. After that I had an ECU DTC. Stupid me reset it before I realized that I should probably remember what it was.
    -Adam Chant
    Tune it or lose it!
    2007 Saturn SKY 2.4L Automatic - E67
    EFILive Tuned
    Jul 2007
    Hi Joel,
    You will have problems with BBL and the E38 PCM. I have been testing on mine and found that if you perform any logging with a scan mode of "stream-fast" it will cause errors resulting in a hung V2 and various errors on the dash. Normally it will appear to log fine for a few minutes before the error occurs.
    To get around this problem in pass through logging, you change the scan mode to "dynamic" ( in the EFI-Live scan tool go to <edit> - <properties> - <logging> then in the scan mode section select "dynamic" ). Doing this has enabled me to log for over 2 hrs with no problems. However there is no way to check or alter the scan mode in BBL, at least not yet. I think that BBL only uses "stream-fast" for all PCM types, hence the errors on the dash.
    Until we get an update to either set the scan mode to "dynamic" for the E38 or allow us to manually set the scan mode in BBL there is not much we can do with BBL. Pass through works fine though so you just need to carry the laptop around.
    Simon.
    Jan 2008
    Thanks heaps for the reply guys. I woke up this morning and turn the ignition on and the ABS warning had stopped.
    I guess when I opened and closed the door to go inside last night the abs warning had reset.
    I will change my settings for pass through on the laptop. Thanks for the tips guys. Will be racking peoples brains in here a fair bit...lol
    Cheers
    Joel
    Oct 2005
    I tried reading the ABS on a 2005 truck recently and did not get any information!? The display read "Service ABS System"
    I did NOT have the "active module detection" enabled, though!
    If I get a chance I will read it again, soon.
    //Lennart
    Joe
    2005 RCSB 2500HD GMC Sierra DURAMAX LLY
    1955 Chevy Truck 1st series, being restored
    2002 Mercedes C270 CDI
  1. E38 TIS Programming warning
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: May 24th, 2010, 12:10 AM
  2. Warning messages in DVT
    By MyM8V8 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 29th, 2010, 08:56 AM
  3. warning-do not change these tables
    By dynarex in forum E37, E38 & E67 PFI ECM's
    Last Post: March 19th, 2008, 01:55 PM
  4. B1501 Low Oil Pressure Warning
    By joecar in forum General (Petrol, Gas, Ethanol)
    Last Post: April 26th, 2006, 10:42 AM
  5. WARNING - Forum is being pruned
    By EFILive in forum General (Petrol, Gas, Ethanol)
    Last Post: July 13th, 2004, 08:41 AM
