Results 1 to 3 of 3
Thread: 6.0 trailblazer
    Jan 2007
    Default 6.0 trailblazer
    could i use the trailblazer ss tuning in my 6.0 1500 pickup?
    im wondering if that would pump up the power to the 390 mark from the 367 factory?
    or is it more than tuning alone?
    08 gmc sierra6.0 4sp-e38/t42 k/n intake
    4x4 ext cab
    No you cant, completely different engines (mostly AL block vs. iron in yours). It would be a good starting point, but you need to do more than just use a TB SS tune file to get the extra hp/tq, its hardware not software.
    Oct 2006
    You can , it may run or it may not , I have , when I first started tuning used different timing tables just to see what would happen some good some bad .
    The best is to start with stock tables and work on them , refining their values to meet your needs .
    A Wide-band is a must , and will help get some of the more important tables in line quicker , remember , AIR , FUEL , SPARK , are the key components of a good running engine and a Wide-band helps correct the first two .
    2006 Trailblazer
  1. trailblazer ss help
    By redws6rocket@yahoo.com in forum E37, E38 & E67 PFI ECM's
    Last Post: April 2nd, 2010, 03:10 PM
  2. Trailblazer tune
    By djms in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: April 15th, 2009, 08:01 AM
  3. trailblazer ss tuning?
    By hot-dog in forum E37, E38 & E67 PFI ECM's
    Last Post: March 17th, 2009, 11:53 AM
  4. 06 Trailblazer and 7.4
    By Chevy366 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: March 29th, 2007, 01:16 PM
  5. Tuning the LS2 in my Trailblazer SS - ECM and TCM?
    By TBSS in forum General (Petrol, Gas, Ethanol)
    Last Post: November 19th, 2006, 05:23 PM
