Results 1 to 3 of 3
Thread: Can anyone see anything wrong here???
    Jan 2007
    Default Can anyone see anything wrong here???
    I'm just about ready to pull my hair out.
    Truck is bucking...again...still.
    I have a feeling it's too rich and that 'MAY' be causing it but I'm not 100% sure.
    I also can't see where AFR's in the 10's are coming from.
    I've also attached the log and tune this screen shot came from if anyone could take a peek and maybe...just maybe someone can see something I can't?
    In this tune....although I had the VE tables pretty well worked out...I decided to lean off the main VE table a little but maybe I should try leaning the boost VE table out a little.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Senior Member SV8346's Avatar
    Nov 2007
    only thing that i can see that would be telling it to go into the 10's for AFR is {B3603}Commanded fuel when in engine protection. Maybe try changing from 1600rpm up to 6000rpm to around 11.9AFR. Other than that there is nothing else telling it to go into the 10's AFR.
    2016 RG Colorado 2.8TD
    Jan 2007
    Thanks,
    I just changed that and I'll see what diff it makes. I'm not holding my breath. Lol!
    If anything I'd think I'm running too cold?
    Howard
    DUCT TAPE.
  1. what am i doing wrong?
    By BadLSX in forum Gen III V8 Specific
    Last Post: May 4th, 2010, 01:24 PM
  2. I think i did something wrong!!
    By 02Tahoe28 in forum Duramax LB7
    Last Post: October 2nd, 2008, 07:44 AM
  3. Something wrong with BBL
    By XLR8NSS in forum FlashScan V2 BB Logging
    Last Post: January 4th, 2008, 10:13 AM
  4. COS #5 what am i doing wrong!!!
    By AGRO in forum Custom Operating Systems
    Last Post: September 2nd, 2006, 12:13 PM
  5. What am I doing wrong?
    By wildwhl in forum Black Box Logging
    Last Post: July 7th, 2006, 12:55 PM
