Results 1 to 1 of 1
Thread: False Knock?
    May 2007
    Default False Knock?
    Anyone care to take a look at this log? Knock retard is pulling out a consistent 3.88* (spikes & falls down, spikes & falls down) of timing under WOT 1st and 2nd, fades out and doesn't do it anymore in 3rd. Commanded timing when knock comes in is between 21.5-23*. No audible ping can be heard. I also am using an LT4 knock module already.
    I did find one tight spot where the passenger side header (collector area) was makin just slight contact with a metal "shroud" around some wiring when the engine torqued up, but haven't got a chance to log and see if that was it.
  1. Possible False Knock
    By Kevin Doe in forum General (Petrol, Gas, Ethanol)
    Last Post: May 13th, 2009, 01:32 AM
  2. What to do when you get false knock???
    Last Post: May 19th, 2008, 02:30 PM
  3. Knock Retard GM.KNKRET vs Retard Due to Knock GM.KR
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: March 9th, 2008, 04:18 AM
  4. Knock after COS #3 install, but never had knock before
    By CRU SS N in forum Custom Operating Systems
    Last Post: June 15th, 2007, 10:07 PM
  5. False Knock?
    By oztracktuning in forum General (Petrol, Gas, Ethanol)
    Last Post: April 9th, 2006, 02:27 PM
