On launch, in between ramp up from 0% to 100% TPS, I go from 26 degrees to (950 RPM idle) 12 degrees at 87% throttle with no KR, then at 100% TPS it then goes to 21.5 showing 4 degrees knock retard.
Why does the timing drop while throttle is intially opening? Is it truly KR but not indicating it?
I can figure out the KR while running down track (lean fuel, too much timing,etc), but is there something in the factory tune that pulls timing on launch or during initial acceleration/throttle opening? I'm guessing this probably hurts my 60 ft....
I'm new to this so hopefully I'm posting in correct forum...
