Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Pros: green horn stuck
    Dec 2007
    Default Pros: green horn stuck
    E38
    Had v1 for years no problem went to V2,working fine on 07 tahoe,will not read CAL on 07 avalanche 6.0 Y engine code.When it starts to read I get this "connection to PCM has been lost check cables...." I have pulled the onstar and audio fuses. Have the V7.53
    Any suggestion ideas
    V1 cant read/flash CAN controllers, including the E38. Need to get a V2.
    Dec 2007
    I went to V2 I am using V2, I think I seen a BCM fuse, if should I pull it ? I am wondering if anyone here has done a avalanch with the 6.0 engine.
    Interesting, you should only need to pull fuses for onstar and audio if you have an aftermarket HU and/or onstar is interfering with the read. have you tried not pulling the fuses? BCM fuse, dont pull it, no reason to and it might mess something up.
    Dec 2007
    I have pulled the onstar and the audio fuses no go. It does have blue tooth added.
    That shouldnt make a difference, thats what I was saying. It should only be an issue if you have an aftermarket HU, and Im gathering you dont so you probably dont need to pull the fuses.
    That said, since you did pull the fuses it should still read, so I dont know. What build do you have, 7.5.3 build 36 is the latest. Also, hook up the flashscan first to the car, then to the computer, then open the tune tool. I know it can be picky on my TrailBlazer. What firmware are you using on your V2?
    Dec 2007
    Eric thanks for taking the time to reply,I really appreciate it.I have the 7.5.3 what I am now hearing is I need to make sure I have the V70 firmware,I believe I have the 60
    That might be it, and no prob. I check here often and although Im still a noob when it comes to tuning anything other than my oddball 4.2L I6 P10, I try.
    Dec 2007
    Folks are here to help ,got input from Justin ,Paul and Eric,Kyle.Thanks to all ,I now have V70 firm,I will try it again Mon. Hope it works
    Jan 2007
    Hmmm....there was another thread here somewhere that someone was having the same/similar trouble.
    I think they pulled the ABS fuse as it was waking up half way through the read/flash process and causing the read/flash to drop out.
    I THINK it was the ABS fuse...sorry can't remember 100%.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
  1. Pros and Cons on 2 ECM's
    By LostCause in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 20th, 2009, 01:02 AM
  2. F302 Green Top Injector Specs
    By white01ss in forum General (Petrol, Gas, Ethanol)
    Last Post: August 13th, 2009, 05:01 AM
  3. Who runs a COS on a NA setup? Pros/Cons???
    By BlackGMC in forum Custom Operating Systems
    Last Post: January 2nd, 2008, 02:48 PM
  4. new dumb and green
    By slowtruck in forum General (Petrol, Gas, Ethanol)
    Last Post: December 10th, 2006, 12:28 PM
  5. SVO 42lb (Green Top) Fuel Injectors
    By Tordne in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2006, 04:14 AM
