Yes I tried
Yes I tried
Here is what I get every time
Check the USB driver version installed on your system - it should be 2.2.4. To do that, connect FlashScan then...
1. Right click on My Computer, select Properties. (Shortcut key is Windows+Pause/Break)
2. Select [Hardware] tab page, click [Device Manager] button.
3. Expand the "Universal Serial Bus controllers" item.
4. Right click on FlashScan V2, select Properties.
5. Select the [Drivers] tab page.
Check the driver version number, it should be 2.2.4.0. If it is not then you should update to the latest driver available here:
http://www.efilive.com/download.aspx#downloads4
OK guys thanks for your patcience and help.It was 2.0 and now have the updated .I will report back tomorrow.I am betting this does it
Did not work.I dont know what to do. Out of frustration I may have to just buy a tuned PCM.Man I hate giving up.
If you want, you can return your V2 to EFILive and we can test it (no charge) to make sure there is no fault in the V2 device itself. Let me know if you want to do that.
mystery solver,dealer had removed pin 6 it was taped up in the harness.read cal. no problem
Glad that you eventually got to the bottom of it
Not glad about the dealer's deliberate sabotage of the OBDII conenctor
Post #13
