Results 1 to 10 of 12
Thread: Help!
    Default Help!
    I'm getting a code P1153 HC insufficient switching bank 2 sensor 1. My mods are LG long tube's Halltech stinger,& Z06 exaust It's a non emissions code & I'm wondering if I should just disable it?
    Lou\'s Automotive, Lake Forest CA.
    03 Anniversary A4 coupe,LGT headers,Z06 exhaust,Haltech air cleaner.
    Guess who's back!!!! Black02SS's Avatar
    Jan 2004
    Its a Oxygen Sensor Code. They aren't getting warm enough and inturn throwing the code. There have been several guys that have resolved this issue, but I have never been able to. Its hit-miss. If you know for a fact that your o2 is good and switching properly, then you can disable it if you chose to, but if your o2 does go bad, you won't be aware due to it being disabled. When this code is throw, the car is more then likely in open loop.
    I didn't like that option so I decided to eliminate my o2's and run in constant open loop. No problems and haven't looked back.
    Quote Originally Posted by black02ss
    Thanks for the reply.Running in open loop is something I rather not do If I can avoid it. I want to try & come up with another solution.It was suggested by LG to eliminate rear 02's & use them as front's Which have been working fine till I started playing with timing related inputs to minimize any possibility of retard. I may have fooled with something I shouldn't of. I was on a roll & the car has responded nicely. I'm new at this & need to learn as much as I can So I quess its time to step back & think?????????
    Oct 2003
    If you back down the Timing/Spark you may be reducing your cylinder pressures and thus combustion heat -> cooler exhaust temps. Just a thought.
    joel
    Senior Member PSWired's Avatar
    Jan 2005
    Don't some people with long tubes use the corvette rear O2s in the front since they have a stronger heater and will keep the sensor hot enough to use with long tubes?
    1995 GMC Yukon 4WD 4DR
    5.3 "LMG" engine: E85 with AFM
    6L80e 6 speed automatic transmission
    Oct 2003
    Quote Originally Posted by PSWired
    Yes. He said he is using the rears.
    joel
    Default Reply
    Thanks all!
    This code has only appeared twice since my last tweeking & reflash.Maybe It's just going to take some driveing time till the learns adjust themselves. I've been trying to learn EFI live one piece at a time. I got the trans shifting nice, Timeing changes seem to be working as the car runs very well. Next is heads & cam & the fun starts, I'm sure this forum hasn't heard the last of me yet LOL ! Regards Lou
    Lou,
    Post a logged chart showing your HO2S voltages (sensor 1 on both banks, i.e. HO2S11, HO2S21).
    Default Reply
    Lou,
    Thanks jocar Will do so! as soon as I can find some time. Lou
    Jan 2005
    Quote Originally Posted by bink
    joel
    Whoops, missed that one.
