Hey guys,
This is my first later model Vortec tune and I am having an issue.
The big problem is there is no drop in A/F Ratio. I have tried the PE tip in TPS, PE based on RPM, PE based on ECT, etc and she lays at 14.7 all the way across the RPM no matter the load on my dyno.
What the hell am I missing here?
The OS is 12587811 and the Cal is 12587806.
If you need me to send the cal file let me know.
Also the customer had a SuperChips on there previously and it does the same thing. Also the same thing with the factory calibration as well.
Thanks in advance guys!
-Kenny
