Just so that your aware blacky this problem is when i am trying to connect the V2 to the laptop in standalone mode to be able to check/program firmware/VIN Licenses. The V2 works fine in passthru mode when connected to the car.
2016 RG Colorado 2.8TD
ok i got a couple of screen dumps from when it is connected to the car
Right, well that pretty much indicates one of two things:Originally Posted by SV8346
1. The USB port on the computer is not supplying more than 100mA
or
2. The USB power circuit in FlashScan has failed and is not providing power to FlashScan from the USB cable.
Given that you have tried it on other computers with the same result, that means it is probably a failed USB power circuit in FlashScan. It will need to be returned to EFILive for repair. Send me an email to paul@efilive.com to organise the return.
P.S. Are those flash counters correct? Looks to me like there may also be a display bug when displaying the flash counters.
ok no worries, not sure about the flash counters as i dont know what they should display. If they are suppose to display the number of flashes that this V2 has performed then they are definitely wrong.
edit: do you have MSN messenger, i would like to chat to you about this first if possible.
My V2 is doing this very same thing now. Who can fix it in the USA?
2005 Twin Turbo Dmax/Allison Ext. Cab Short Box 4X4
Best 1/4 11.8 @ 118+ on #2 only
Twisted Diesel Tuning-The leader in Duramax Tuning Services and soon to offer Common Rail Cummins Tuning!
Bobotune at rocketmail dot com
Warranty returns in the US are handle by Ira at Fish Tuning in CA, Phone: (310) 499-0989.Originally Posted by bobo
Thank you. I just called!Originally Posted by Blacky
