Results 1 to 4 of 4
Thread: Displacement on Demand
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Default Displacement on Demand
    Can anyone tell me exactly what hardware is required to be able to enable DoD in the E40 ECM? Also, I've noticed in the E38 that there's an "Active Fuel Management" instead of "Displacement on Demand". I assume they are the same thing, just named differently?
    Does anyone know if DoD hardware from a 5.3L will work on a 6.0L? Which ECM would be best to use with 6.0L and T42TCM? The E40 or E38?
    There is a lot of underlying calibrations in the DOD / AFM area that we don't show (or understand what they do). 99% of the requests for DOD / AFM parameters are 'to turn it off' !
    Why the name change?, not sure, just GM media working hard I guess.
    Jan 2006
    Why would one WANT to turn it off? I'd like to drop a Flexfuel and DoD enabled 6.0L (or 6.2; not sure yet) into an F-Body to get 400+ ponies available, along with excelent fuel economy (I'd think).
    The L76 is a 6.0L with DoD hardware and is rated at 348HP. how much of that is in the tune vs hardware (versus the 400HP 6.0)?
    Turn it off because when you bolt up an aftermarket exhaust it sounds like crap and drones when it goes to 4cyl mode. Also, most people think the 6-8% better mileage isnt worth the hassle plus it makes tuning a little more challenging (speaking about the 5.3L that comes in the TrailBlazers and mail order tunes).
    The 6L engines are different at a hardware level, the LS2 is an AL block vs iron block, internals are different (so Ive been told).
  1. Displacement not on pull down
    By dennisscars in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: May 24th, 2009, 01:15 PM
  2. Parameter for cubic inch displacement...
    By TFZ_Z06 in forum Gen III V8 Specific
    Last Post: June 21st, 2008, 06:21 PM
  3. Demand of 7.0
    By 87gmc in forum General (Petrol, Gas, Ethanol)
    Last Post: November 22nd, 2004, 09:28 PM
