Results 1 to 10 of 10
Thread: Engine won't stop fueling
    Feb 2008
    Default Engine won't stop fueling
    06 lbz Dmax
    Will someone checkout this tune and tell me what i did wrong? Engine starts and idles fine, but put it in gear and give it some fuel? Awsome throttle response but let off and the engine keeps fueling. Also threw pcm internal code 6061? not entirely sure on the DTC code number. Only tried this for about 2 min.
    Feb 2008
    Correction DTC code P0606
    Senior Member lakingslayer's Avatar
    Dec 2005
    Just a quick glance I noticed you have a value in the 0mm3 row of table B1102. Why do you want fuel when it's demanding 0mm3?
    Also if you aren't very familiar with tuning I'd make small changes and see how things work one change at a time and do lots of logging. This will help you a lot getting familiar with the way the truck ECM thinks. It also makes it easier to troubleshoot trouble spots like this.
    Sep 2006
    I would be cautious of highlighting certain tables and just adding 20%, seems to cause problems in the idle areas...Compare this tune to yours and you'll see some differences...This tune is fairly mild, but seems to work well...
    2007 CC/SB 4WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SD Sleeves, SoCal Diesel
    2002 CC/DRW 2WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SoCal Diesel
    Feb 2008
    lakinslayer,
    Thanks for spotting that one i think i accidently blended the whole table to get that value in 0mm3 of B1102.
    also seem to be having conflicts with use of my edge juice with attitude (stock setting only) for guages.
    Back to the grind stone.
    Dec 2005
    Quote Originally Posted by roadkill81304
    lakinslayer,
    Check out what The Neens posted. He's got some good tunes and knows what he's doing. I'd get rid of the Edge and get some real guages. I'm not sure about the LBZ but the LLY's version of Edge still messes with timing even on level 0. Good luck.
    Mar 2005
    also make sure to compare the area that is changed in the neens tune and yours on the B0720 table. Yours is into an area that effects idle quality and can make the engine can stay at a certain rpm even when letting off the throttle.
    Feb 2008
    hey guys,
    I really appreciate all your help. I studied graphs and tables for hours and couldn't see something that simple. I decided to go a differrent direction based on your advice. so far with the minimal changes i have done i have already surpassed the level 5 performance of the juice w/attitude.
    This software definately has infinate possibilities, can't wait to learn to harness them all.
    Feb 2008
    Has anyone used the Edge Insight guage system, and does it show fuel rail pressure?
    Sep 2007
    yes and yes it does
  1. N2O fueling.. ONLY VE?
    By Highlander in forum Custom Operating Systems
    Last Post: December 20th, 2009, 07:27 AM
  2. De-fueling at shift
    By tblu92 in forum General (Diesel)
    Last Post: November 4th, 2009, 11:27 AM
  3. can't stop hitting reduced engine power
    By 496chevy in forum Allison 5 & 6 Speed
    Last Post: May 28th, 2009, 02:24 AM
  4. Still trying to get fueling there
    By DaddySS in forum General (Petrol, Gas, Ethanol)
    Last Post: June 11th, 2007, 01:42 PM
  5. Over Fueling 408
    By overdrive915 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 26th, 2007, 08:18 AM
