Results 1 to 10 of 16
Thread: Lean AFR after injector swap
    May 2006
    Default Lean AFR after injector swap
    I just put in a set of 79# injectors, and all i changed was the injector flow rate to match the injectors and the afr is real lean, 14:1, should be 9.8:1 and it idles real strange kinda like the lope from a big cam. I tried reducing B4307 with no change, I can correct it with A0008 at 1.25. But i would think i should not have to use this to correct it, just looking for some thoughts on this. Here are two of the logs, the first log is uncorrected the second is corrected with A0008 at 1.25. the idle increased as well with the correction which tells me there may be a vacume? leak but i didn't find one.
    2002 ws6 stock short block
    GMPP cnc LS6 Heads 11.4:1 cr
    .576 i .581 e 116 lobe
    D1SC @ 10#
    723 rwhp 654 rwtq on E-85
    Jul 2005
    injectors can achieve their full potential only when the rest of the fuel system is up to the task. what other supporting fuel mods you got in there?
    May 2006
    I have an APS dual in tank fuel pump, Aeormotive fuel pressure regulator. Thats it though, the fuel rails i got with the kit wont fit the injectors so i can't use the two -6 supply lines either, just using the stock feed line with a Magna fuel filter in place of the stock one. I do how ever, have the fuel pressure kind of low at 45 psi.
    D1SC @ 10#
    Jul 2005
    is it always low or just on WOT? is your IFR table calculated for the 45psi or the stock 58?
    May 2006
    I have not even taken it out of the garage yet, it has very little gas. I just installed everything over this last weekend. I was just checking to make sure everything is in working order and to adjust the regulator, but from the limited reving it stays dead on 45.83 psi. And yes, i used one of your excel spread sheets to calculate for 45 psi., then input that into the IFR table. I didn't want to set the fuel pressure too high because i could not get the 60#er's i had before the D1 and E-85, to work right. I haven't been able to figure out how to properly tune for large injectors yet, I thought it would easier if the pressure was lower. Also the regulator is not referenced too manifold vaccume, so it should be constant.
    D1SC @ 10#
    Oct 2006
    Quote Originally Posted by vatman02
    Not referenced to manifold pressure is a curve, referenced is a constant.
    May 2006
    Quote Originally Posted by 5.7ute
    Doesn't this only apply to the IFR table, not fuel pressure?
    D1SC @ 10#
    Jul 2005
    IFR table is a result of fuel pressure, so you change one you change the other.
    Fuel pressure:
    - unreferenced regulator -> fuel pressure stays constant
    - MAP-referenced regulator -> fuel pressure varies as MAP varies (MAP "assists" the spring inside the regulator)
    IFR:
    - unreferenced regulator -> sloped IFR tble
    - MAP-referenced regulator-> constant flat IFR table
    May 2006
    Fuel pressure:
    IFR:
    That's what I was thinking. I have a constant fuel pressure and a sloped IFR table. Any thought's on why I'm running so lean. I am going to try reverting the voltage offset table back to stock and see what it does.
    D1SC @ 10#
  1. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 12:44 PM
  2. pcm swap
    Last Post: August 18th, 2009, 06:10 AM
  3. 01 s-10 to LS1 swap q
    By cajundragger in forum General (Petrol, Gas, Ethanol)
    Last Post: January 23rd, 2009, 04:48 PM
  4. lean wot with big ve numbers and low injector duty cycle
    By 69camaro5speed in forum Custom Operating Systems
    Last Post: July 28th, 2007, 03:48 PM
  5. Injector offsets and injector slopes....
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: June 19th, 2006, 01:32 AM
