Table B1901 --- Does the value in this table only limit torque when the traction control system is activated ( button turned on)
OR is this value used ALL the time regaudless if the TC button is on or off ??
Some people adjust this valve to the max setting so as to NOT limit engine torque ALL the time---But I thought it only limits torque while the TC system is being activated---I see many interpretations----
Also i thought to limit torque ALL the time tables B6611 & B6614 thru B6620 are used---
