Results 1 to 6 of 6
Thread: DTC O2 sensor
    Lifetime Member hymey's Avatar
    Jan 2008
    Default DTC O2 sensor
    Hey guys I have a VE SS running in open loop with e38 pcm. I have the precat O2 sensors disconnected at the plug.(I would plug them back in but they are a pain to get to.)
    The car emits the engine warning light on the dash. I check the scan tool and it shows a DTC for the O2 sensors. I clear the DTCs start the car and the warning goes. But once I restart the car the warning returns and I have to clear them again. I have played with other settings under edit-properties but this doesn't help. Am I able to turn of the DTCs elsewhere than where I am looking. Normally once I clear them they don't return but this time they keep coming back.
    cheers
    Joel
    Umm, have you turned the O2s off in the Engine Diagnostics section? There should be a list of DTCs you can kill, just find the O2s and click Not Reported (or whatever it says).
    Jan 2008
    Thanks mate,
    I will have a fiddle tonight but I went into the the DTC dispaly page(the red button) and cleared them(green button) but I will try the other section and turn them off in there as not reported.
    Cheers
    Joel
    Yea, what you are doing is just clearing them, not turning them off. Thats why they come back all the time, if you set them to not reported then the codes will never be thrown.
    Jan 2008
    sweet, fixed it up. Thanks, Didnt realise that bit was there in the tune page
    Glad to hear you got it fixed!
  1. TP sensor
    By Slowrc in forum Gen III V8 Specific
    Last Post: January 29th, 2009, 06:24 AM
  2. TPS sensor?
    By DaddySS in forum General (Petrol, Gas, Ethanol)
    Last Post: December 10th, 2007, 01:28 PM
  3. Anyone know of a 1.5 bar MAP sensor?
    By mistermike in forum General (Petrol, Gas, Ethanol)
    Last Post: August 19th, 2007, 08:57 PM
  4. IAT sensor
    By Chevy366 in forum Lounge
    Last Post: August 3rd, 2007, 11:49 AM
  5. O2 Sensor
    By ASSAMI in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2006, 02:04 AM
