Results 1 to 10 of 20
Thread: Installing wbo2
    Dec 2007
    Default Installing wbo2
    Ive been looking at the tutorial in efi live and I don't understand where you are supposed to wire the two wires you cut from the nb02 sensor, what do you wire them to? I have the plx widband kit. And also on the afr output to the flashscan interface how do you know what side to use for ground and power?
    98 vette, 402 stroker, comps xtreme Advanced dur-273/279, Dur@.050 224/230 lobe sep:114, Comp 1.75 roller rockers, Patriot stg 3 heads, 90mm fast intake,90mm ls2 tb, 42lb/hr bosh injectors, fast fuel rails w/regulator to 58psi, 160 stat, pacesetter headers, slp cats, magna flow x pipe and mufflers, msd 8245 coils and wires, 3:73 gears, and tring learn how to tune with the v2:
    Jan 2007
    Hope this helps!
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Jan 2007
    Don't cut anything. Tie the narrow band up out of the way and use the WBO2 exclusively.
    Howard
    DUCT TAPE.
    Yeah, forget about NBO2's and NBO2 simulation... you won't need either during Auto VE tuning.
    Dec 2007
    alright, thanks guys that helps a bunch i appreciate!!
    Dec 2007
    Does it matter what side i put the ground wire on into the flashscan interface?
    Lifetime Member limited cv8r's Avatar
    May 2005
    Does this help? Page 104 scan manual. There should also be a sticker/label on the rear of your V2 indicating + & - for each terminal connection.
    Dec 2007
    Yeah that does help, guess i should of looked a little harder
    Dec 2007
    Ok i got my wide band all set up and i went out and did some logging and every time i step it to the floor or not ever quite that it goes in to reduce engine power and cuts several cylinders and i have to pull over and shut it off for a min or so and then it is ok agian untill i step really hard agian. Got ne ideas why this happens?
    Jan 2007
    Sorry Adam...no idea.
    It wasn't doing this before?
    Check....double check your wiring.
    Are you running open loop...speed density as per the AutoVE tutorial?
    Double check the AutoVE tutorial again.
    Howard
    DUCT TAPE.
  1. How do you log WBO2 lambda instead of AFR?
    By waveoff in forum General (Petrol, Gas, Ethanol)
    Last Post: August 13th, 2009, 08:03 AM
  2. WBO2 controller
    By Thumper in forum General (Petrol, Gas, Ethanol)
    Last Post: January 6th, 2008, 12:53 PM
  3. wbo2 opinions
    By warscout2 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 30th, 2007, 04:16 AM
  4. Which WBO2 would work the best for......
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 27th, 2006, 03:41 PM
  5. WBO2 location question (C5)
    By bobfo in forum General
    Last Post: September 23rd, 2005, 01:52 AM
