Results 1 to 2 of 2
Thread: Negative Timing in High Load and Low RPM areas?????
    Jan 2007
    Default Negative Timing in High Load and Low RPM areas?????
    Why is there negative numbers in the High and Low octane table in the High Load (Grams/Cylinder) and Low RPM areas???? Mainly .56-.72 and < 1000 RPM, is this partially responsible for the off idle bog? I was breifly hitting those cells while I was tuning yesterday when I would punch it for idle..... The BEN correction values for those cells kept wanting me to lean out the mixture in those cells. I have basically removed all the TM except right before the shift points so I don't think it is TM kicking in....
    Jan 2007
    I wouldnt think the engine would be as loaded becuase the converter is still stalling up below 1000rpms, but the timing on trucks does get really negative in thoes cells.
  1. Timing going NEGATIVE randomly...help please
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: July 22nd, 2009, 03:25 AM
  2. base timing in gear vs high octane question
    By Kurtomac in forum Gen III V8 Specific
    Last Post: April 29th, 2009, 02:25 AM
  3. Excess Timing in low load areas causes surge/buck issues, and how I fixed it.
    By ArKay99 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 5th, 2008, 12:08 PM
  4. Optimal Timing vs High Octane tables
    By efizjb in forum Gen III V8 Specific
    Last Post: March 11th, 2008, 05:32 PM
  5. Making real time timing changes on load dyno??
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: October 23rd, 2005, 04:33 PM
