Good day,
I am going to be swappin my 75mm(Stock) TB for a 90mm. I made the needed adjustment to B4349 but where else should i mod for this upgrade?
Good day,
American Muscle, European Design, Japanese Tactics
i was hopin for an answer, but no one has one for me
Take a look at my attached tune. In particular B4403. This is what I changed based on a Holden that comes with a 90mm TB. It worked out great. This is an old tune of mine and has other problems, but B4403 is still the same for my current tune (which I don't have on this computer)...
Derrick
1969 Camaro, LS3, 4L80E, Dana 60 rear, Air Ride, 19 and 20" wheels, Baer Brakes, and a lot more.
2008 Charger SRT-8 Super Bee, Exhaust and Cold Air kit (Wife's car)
2007 Yukon XL Denali, Family Hauler
http://s330.photobucket.com/albums/l...i/69%20Camaro/
TTT, I'm installing an LS2 90mm TB soon. How did this work out?
Aaron
'03 Z06 Corvette - The normal stuff...
EFI-101, EFI Advanced, EFILive-101
EFI University Evangelist
2003 red vert
Mods:
LPE 100mm MAF
RPM Level 6/4L60e trans
3.42 gears
Yank SS3600
1-7/8" AR headers
Z06 exhaust
470rwhp 437rwtq
Jeff,
Any words of wisdom on the FAST 90 and LS2 90mm TB?
Thanks!
Aaron
I put a ported FAST and ported LS2 TB. I had to make ZERO changes, except for WOT tuning. The car will be tested in about 2 weeks. I expect its going to run 10s around 125-126. There was no bad behavior as a result of the change.
The main thing I did was return top end fuel. I hope to get around to looking closer at light throttle, when I do VE later, but with fuel trims at virtually 0, I'm hard pressed to mess with it.
So, the answer is, there are no big changes.
07 Silverado DMax Classic
02 Z06 LS3 416, 805rwhp, TFS245, Wiseco, Callies Crank/Rods, Iskendarian Lifters, Crower Rockers, FAST102/90, ATI Damper, 1-7/8 Kook's LT, QkTime Shield,Tolle-Fab 8pt
Old Engine: 1/4mile = 9.6/146 New Engine:?
EFI Live Tune/Scan v7.5.27, EFI Live Scan and Tune v8.2.23, build 276, BootBlock 2.07.06, FirmWare 2.07.52, 512K RoadRunner (12.14.R), Innovate Serial LC2x2
COS5/12212156 For 2002 Z06 Manual Vette
The FAST and LS2 TB conversion should be easy IF the FAST seals up ok and does not crack or warp. They seem to always need a little tightening till the worst happens--.
I think the newer ones have brass insets in the fastener lugs which may help.
As far as tuning for idle a quick start is a big B4309 (~.0300) but a stock .0255n and a few RAFIGs should fix idle. The B4307 is all you should need for idle. Don't go nuts changing lotsa settings, cause you will chase your tail. It should settle in with just B4307 correctly. (Read from MAF air flow)
Bruce
PowrMax Performance
100 mm PowrMAF
