Hi guys,
I came across this problem yesterday with a late 2007 VE. Here's a break down of what has happened...
- On Monday, I could log all the PCM DMA PID's without problems ( OS - 12619078, CAL - 12619077 ).
- On Tuesday morning, I logged the TCM, again no problems.
- On Tuesday evening, I tried to swap back to logging the PCM and could not validate the DMA PID's. All other PIDS seemed fine and worked as expected. Only the PID's in the E38 section were "invalid".
- I then tried connecting to an older E38 OS, ( OS - 12607218, CAL - 12607217 ) and this worked fine. All DMA PID's were valid.
- Swapped back to the 1261907 OS and no go with the DMA PID's
Here's a clip from the scan tool console.....
Code:
06:53:22.391: Disconnecting ...
06:53:22.441: CAN-VPW Bridge Deactived
06:53:22.441: Disconnected
06:54:01.898: Scanning for EFILive FlashScan V2 HAPI
06:54:01.908: Autodetect interface ...
06:54:02.058: CAN-VPW Bridge Actived
06:54:02.078: Current protocol set to: "ISO 15765 CAN"
06:54:02.139: Interface firmware version: 2.5.15
06:54:02.139: Connection to [FSV2] interface is OK
06:54:02.139: Autodetect PCM...
06:54:04.262: PCM not detected.
06:54:04.262: Autodetect ECM...
06:54:04.282: Connection to ECM is OK
06:54:04.282: Autodetect TCM...
06:54:04.312: Connection to TCM is OK
06:54:04.332: Current protocol: "ISO 15765 CAN"
06:54:04.382: Interface firmware model: FSV2
06:54:04.402: Interface firmware version: 2.5.15
06:54:04.422: Interface firmware date: Jan 07, 2008
06:54:04.442: FlashScan serial number: 003653XXXXXX
06:54:04.462: FlashScan license number: 003653XXXXXX
06:54:04.532: Request GM VIN...
06:54:04.662: VIN: 6G1EK54H98LXXXXXX
06:54:04.662: Request serial number...
06:54:04.792: Serial number: 86K172XXXXXX
06:54:04.792: Request hardware number...
06:54:04.792: Hardware: 0
06:54:04.892: Request GM operating system...
06:54:04.913: GM operating system: 12619078
06:54:04.913: Request GM NVM...
06:54:04.933: GM NVM: 12619077
06:54:04.933: Request GM Engine calibration...
06:54:04.963: Request GM Engine diagnostics...
06:54:04.983: Request GM Transmission calibration...
06:54:05.013: Request GM Transmission diagnostics...
06:54:05.043: Request GM Fuel system...
06:54:05.063: Request GM System...
06:54:05.083: Request GM Speedometer...
06:54:05.113: Request GM BCC...
06:54:05.153: GM BCC: YRPS
06:54:05.153: Request GM VAT/IGN Cycles...
06:54:05.183: GM VAT/IGN cycles: 0
06:54:05.183: Request GM oil life...
06:54:05.213: Oil life: 76
06:54:05.213: Query support for stream.01 scan mode...
06:54:05.503: Query support for stream.02 scan mode...
06:54:05.624: Calculating number of dynamic packet ID's...
06:54:06.325: Loading generic configuration file: sae_generic.txt
06:54:06.325: User defined calculated PIDs file: calc_pids.txt
06:54:06.325: Enhanced configuration file: gm_enhanced.prn
06:54:07.466: Request GM VIN...
06:54:07.596: VIN: 6G1EK54H98LXXXXXX
06:54:07.707: Request GM operating system...
06:54:07.727: GM operating system: 12619078
06:54:07.767: Validating PIDs...
06:54:07.887: Validating Modules...
06:54:07.957: Initialising PIDs...
06:54:08.458: Initialising Modules...
06:54:08.458: Ready.
06:54:29.388: Req Current DTCs...
06:54:29.418: Req Pending DTCs...
06:54:31.561: Autodetect interface ...
06:54:31.591: CAN-VPW Bridge Actived
06:54:31.621: Current protocol set to: "ISO 15765 CAN"
06:54:31.681: Interface firmware version: 2.5.15
06:54:31.681: Connection to [FSV2] interface is OK
06:54:31.681: Autodetect ECM...
06:54:31.711: Connection to ECM is OK
06:54:32.743: Request DTCs for "Engine Control Module (ECM)" ($11)...
06:54:34.785: Request DTCs for "Transmission Control Module (TCM)" ($18)...
06:58:10.185: Programming PID GM.ETCTP, into dynamic packet 0[0..1] offset: 0...
06:58:10.205: Programming PID SAE.FUELSYS, into dynamic packet 0[2..3] offset: 2...
06:58:10.235: Programming PID SAE.RPM, into dynamic packet 0[4..5] offset: 4...
06:58:10.265: Programming PID GM.HO2S11, into dynamic packet 1[0..0] offset: 0...
06:58:10.295: Programming PID GM.KR, into dynamic packet 1[1..1] offset: 1...
06:58:10.315: Programming PID SAE.ECT, into dynamic packet 1[2..2] offset: 2...
06:58:10.345: Programming PID SAE.IAT, into dynamic packet 1[3..3] offset: 3...
06:58:10.375: Programming PID SAE.LONGFT1, into dynamic packet 1[4..4] offset: 4...
06:58:10.406: Programming PID SAE.LONGFT2, into dynamic packet 1[5..5] offset: 5...
06:58:10.456: Programming PID SAE.MAP, into dynamic packet 2[0..0] offset: 0...
06:58:10.476: Programming PID SAE.SHRTFT1, into dynamic packet 2[1..1] offset: 1...
06:58:10.506: Programming PID SAE.SHRTFT2, into dynamic packet 2[2..2] offset: 2...
06:58:10.536: Programming PID SAE.SPARKADV, into dynamic packet 2[3..3] offset: 3...
06:58:10.566: Programming PID SAE.VSS, into dynamic packet 2[4..4] offset: 4...
06:58:10.606: Using scan mode: Dynamic
If there is anything else you want me to try, let me know.
Simon.
