For some reason, EFILive is not programming the two E38 DMA PIDs into the ECM. Therefor the ECM does not return valid data for those two PIDs.
Prior to logging, can you please perform the PID validation using menu option: Info->Validate PIDs.
Then make sure the two E38 PIDs are not marked with a red X in their icon on the F8 tab page.
When logging, watch the F12 tab page and make sure ALL PIDs are programmed into the ECM
It should look something like this: (notice the first two PIDs are the E38 DMA PIDs)
Code:
09:38:32.881: Programming PID E38.AFRATIO_DMA, into dynamic packet 0[0..1] offset: 0...
09:38:32.920: Programming PID E38.APCYL_DMA, into dynamic packet 0[2..3] offset: 2...
09:38:32.958: Programming PID SAE.RPM, into dynamic packet 0[4..5] offset: 4...
09:38:32.990: Programming PID SAE.ECT, into dynamic packet 1[0..0] offset: 0...
09:38:33.002: Programming PID SAE.IAT, into dynamic packet 1[1..1] offset: 1...
09:38:33.014: Programming PID SAE.MAP, into dynamic packet 1[2..2] offset: 2...
09:38:33.045: Programming PID SAE.SPARKADV, into dynamic packet 1[3..3] offset: 3...
09:38:33.077: Programming PID SAE.TP, into dynamic packet 1[4..4] offset: 4...
09:38:33.109: Programming PID SAE.VSS, into dynamic packet 1[5..5] offset: 5...
09:38:33.151: Using scan mode: Dynamic
09:38:34.998: Req Current DTCs...
09:38:36.031: Req Pending DTCs...
09:38:37.079: Request DTCs for "Engine Control Module (ECM)" ($11)...
09:38:39.330: Request DTCs for "Transmission Control Module (TCM)" ($18)...
