DTC Bug
Paul, think I've got a Standalone DTC bug for you... I've got some DTCs active in my truck, and here's what I get:
Standalone - PC
B0035 - C0035
B0040 - C0040
U1016 - U1016
C0004 - B0004
C1000 - B1000
C1009 - B1009
U1000 - U1000
C2425 - B2425
Seems the "C" & "B" codes are goofed...
EFILive Developer
Site Admin
Good catch.
The FlashScan firmware was wrong. It is fixed now and will be available in the next beta firmware update.
I also have this issue. I plugged in the V2 and scanned for codes and got the following:
Node DTC Status
All C2961 ---H---S
All U1016 ---H---S
TCM U1016 --PHX--S
All U1016 ---H---S
All U1000 ---H---S
All U1000 ---H---S
All U1016 ---H---S
All U1016 ---H---S
All U1016 ---H---S
All U1016 ---H---S
All U1016 ---H---S
I cleared the codes using the V2 with success according to the V2 and scanned again and got the following:
All U1016 ---H---S
All C2961 ---H---S
All U1016 ---H---S
All U1016 ---H---S
All U1016 ---H---S
All U1016 ---H---S
All U1000 ---H---S
All U1016 ---H---S
All U1016 ---H---S
It changes every time I clear but it doesn't clear the codes unless I use the scan tool.
I'm using the latest beta FW and SW for BB logging. Sorry if this has been covered before but I didn't see it if it has.
EFILive Developer
Site Admin
After you display the DTCs, can you please generate a trace file using the FlashScan menu option: F2 Scan Tool -> F4 Scan Options -> F1 Save Trace File.
Please copy that trace file off FlashScan to your PC, then send it to me at paul@efilive.com
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
