Results 1 to 4 of 4
Thread: Knock Retard GM.KNKRET vs Retard Due to Knock GM.KR
    Feb 2007
    Default Knock Retard GM.KNKRET vs Retard Due to Knock GM.KR
    Why are they different? I'm logging both and getting different results????
    Feb 2007
    Anybody?
    Below are the maps of both pids from a recent log with differing results. Max values.
    I think GM.KR is the required pid, with GM.KNKRET picking up the same knock and more??
    GN.KR
    GM.KNKRET
    Feb 2007
    Heres a stab in the dark, could GM.KR be spark reduction as a result of data recieved from the knock sensor and GM.KNKRET be spark reduction as a result of data recieved from the knock sensor combined with other PCM calculated knock reduction?
    This makes sense as there is a band seen between 3600rpm and 4800rpm with the common value 3.87
    Feb 2007
    GM.KNKRET pid is the amount of retard to prevent burst knock from from i think {B1914} and its effect seen on this log, just after a change in TP. No GM.KR either.
  1. How to map knock retard?
    By jorge in forum General
    Last Post: August 13th, 2008, 09:31 AM
  2. Knock Retard follows RPM
    By vortecfcar in forum Gen III V8 Specific
    Last Post: June 1st, 2008, 06:02 AM
  3. Knock Retard
    By esco35m in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2007, 12:51 PM
  4. How do I log knock retard?
    By zapp168 in forum General
    Last Post: July 23rd, 2007, 09:32 AM
  5. knock retard
    By blackblowngto in forum General (Petrol, Gas, Ethanol)
    Last Post: August 5th, 2005, 11:50 AM
