I have just realised that the trans shift program goes back to "normal" from "performance" each time I turn the ignition off.
This explains why I could not get it to feel like I wanted for very long...and a run on the track had two different but consistent times.
I do not have the factory switch and LED set up so I am never really sure which mode I am in unless I scan it.
Anyway, I have copied over all the cells from the performance areas to the normal areas. The performance section allows you to turn off the learned shift process and I assume normal does not?
Also is there likely to be any ill effect from copying the performance transmission tables over the normal tables including the performance desired shift times. As this has been disabled under performance I assume it has had no effect to date?
Are there any other factors to consider ?
cheers
Mal
