Results 1 to 10 of 11
Thread: Keep TCC locked in 4th gear
    Feb 2008
    Question Keep TCC locked in 4th gear
    Hey all, I have a bit of a problem that has been bugging me
    First off, I own HPTuners equipment, and I want to see if the feature is available in EFILive to solve my problem.
    I have a 2002 Silverado 1500HD LQ4 and a 4L80E. What I want is to not have the TCC unlock in 4th gear when i let off the throttle. When the tps gets near to 0% (usually 2% or less) the converter comes unlocked. I understand the converter will unlock when the brakes are used, but is there a way i can have 4th stay locked with no throttle using EFILive? I just want to know if it is possible to do in the VCM, or if it is something hardcoded.
    Thanks in advance!
    Feb 2006
    You can download a demo of EFILive here:
    http://download2.efilive.com/Softwar...666_657_60.exe
    And download this file to see if what you are looking to edit exists.
    http://www.holdencrazy.com/EFILive/T...012212156).tun
    Feb 2006
    Or download the newer version of EFILive here:
    http://forum.efilive.com/showthread.php?t=7092
    You'll want to look at table D1006.
    Feb 2008
    Hmm...Thats 1006 is CLOSE, but not it. Im referencing an enovy LL8 4l60, and for 0% TPS the tcc should release at 68km/h(68mph). I happen to have a trailblazer ll8 4l60 (it has the same problem as my 1500HD btw) and it unlocks no matter what speed you're doing when you let off. could be 120mph, it still opens up when you quit jammin on it for a second. Thanks though.
    Default Releasing TCC on throttle release
    Some OS's will release the TCC regardless of the release tables.
    Some truck OS's release; the F-body and Y-body OS's do not.
    You would have to get OS 12212156 (2002 F-body) [which I know does not release], and then you would copy all your tables into it, and then you would copy your 4L80E calibration into it (some members of this forum have built a 4L80E file from a 4L60E file like this).
    You can do this with the EFILive software that Al linked you to (you only need a license when flashing).
    My LL8 does it too, I really wish it didnt though. Gets annoying on the hwy with the TCC unlocking when I pull my foot off the gas and taking a sec to relock when I put my foot back into it.
    Jan 2007
    This sounds like a good idea. I'd like to be able to do the same.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    It would be easier if there was a parameter to enable/disable it, but I'm not sure if this is how GM did it or if they hard coded it.
    Jan 2007
    Yes Joe....that would be ideal.
    I noticed yesterday whilst driving/logging (the kids..."oh...are you still doing that thing with the laptop? How long does it take to tune a car?") that the converter locks up at around 72kph in 4th andwon't unlock if I hit the gas...which I really need as the truck loads up and starts pinging.
    Howard
    DUCT TAPE.
  1. locked ECM
    By duramaxdaddy29 in forum Duramax LB7
    Last Post: June 4th, 2008, 05:30 PM
  2. E40 ECM locked
    By LBZ_YFZ in forum Gen IV V8 Specific
    Last Post: April 4th, 2008, 01:37 PM
  3. '06 E40 PCM locked
    By 98TJ in forum Gen IV V8 Specific
    Last Post: December 12th, 2007, 04:22 AM
  4. My PCM locked me out! Need Help!
    By 98S10LS1 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 24th, 2007, 01:46 PM
  5. Locked PCM?
    By eboggs_jkvl in forum General (Petrol, Gas, Ethanol)
    Last Post: March 16th, 2006, 01:46 PM
