Hi Guys,
I've been playing with SD on the E38 and come across an interesting problem. I'm testing on a manual car and applied both TCS patches and performed a full re-flash. Now when performing acceleration tests and changing from first to second, I get a huge stutter just as I get back on the power after the gear change.
The first time it happened, Jezza an I thought it may have been fuel surge as the tank was low and I'd just performed a left turn. But it happens nearly every time I do a gear change after letting it rev out a bit. Quick changes at lower RPM's don't see the stutter, only when there's a good chance of traction loss on a gear change.
Before anyone asks, yes the TCS was switched off using the console switch, so it should not be active. Turing the switch off when running without the patches ( and with the MAF enabled ) results in good powerful shifts with no torque reduction.
To test out my theory that the patches may not be working correctly, I disabled all TCS settings in the tune and set the TCS enable RPM to 8000. I then went out again to see what the difference was. This time, not stutter. I've attached some log segments to show what is happening.
log_TCS.efi shows the stutter on gear change, in it you can see...
- The throttle opening rate slow down. ( remember this is an ETC vehicle ).
- A sharp drop in spark advance.
- fuel mixture leaning right out. Though I'm guessing that this was more due to the rapid throttle opening.
the only TCS settings enabled in the tune for this were TCS reduction by spark and TCS reduction by throttle. TCS reduction by fuel was disabled. Again, remember that traction Control was turned of by the switch for this run.
log_no-TCS.efi shows no stutter at all
Any idea's on this one? I must admit I almost needed a change of pants after the first time it happened.
Simon.
