Results 1 to 6 of 6
Thread: Newbie ? EFILive v4 95 Riviera Vin 1 3.8 SC
    Feb 2008
    Default Newbie ? EFILive v4 95 Riviera Vin 1 3.8 SC
    Hello, I have some Newbie questions I recieved my obd to usb cable and I'm trying to connect and stream some data from my pcm
    Vin 1 is the correct def file. for this car from what I gather. EFILive needs to have either the diagnostic or clear code line selected at the left.
    I have streaming characters across my HyperTerminal screen***Now I connect to car and EFILive v4 w/ vin 1 loaded for 3.8 engines, I set com port 3, then click on the engine data selection and hit the green go and it seems to connect for a moment and then I recieve an error about com port timing out, then it connects and runs through a couple steps and times out again ...etc....until it finally stops, then the green sign turns green again. I can sent screen shot if need be.
    ? Is the pontiac file on EFILive v4: 95KL363.8 Pontiac Bonniville SE1995 Pontiac Vin K.zip and 951L673.8Pontiac Grand Prix GTP or Bonnieville SSEI1995 Pontiac Vin 1.zip suppose to work with my car? Sorry for all the newbie questions....just trying to figure this out.
    1995 Buick Riviera 3.8 SC
    3.8L Vin 1
    Tranny 4t60-e
    Pcm 16 pin 16197428 module
    V4 will work with dedicated USB-ALDL cables, what it won't work with is a generic USB to serial converter.
    Actually its not EFILive V4 that doesn't like the generic serial-usb converters, its the PCM. The PCM transmits/receives data at 8192 baud. The closest baud rate that a real serial UART can get to that is 8200. That's what EFILvie sets the UART to in a PC with a real RS232/UART port.
    Most generic usb to serial converters only support the "standard" baud rates of 9600, 19200, 56700 etc... None of those baud rates will allow communication with the PCM.
    Anyway, if you are seeing valid data in hyperterminal it sounds like it is working ok.
    In EFILive V4, select the menu option View->Show Serial IO, that will display more detailed information/diagnostics about the communication between the PC and the PCM.
    Then, click on the Display ALDL chatter toolbar icon. Let that run for about 5 seconds and then click stop.
    Right click in the text window and select "Copy All", paste the copied data into and email and send it to me.
    (I have also sent this reply to your email request).
    Feb 2008
    Thanks much......after some fine tuning thanks to your help I was able to get some readings......
    07:07.021: Initialising...
    07:07.981: Opening COM4 8228,8,N,1
    07:08.187: Ready.
    07:33.930: Scan for chatter...
    07:33.930: Waiting for Aldl bus silence of at least 50ms...
    07:34.171: (07:34.155)$90,$59,$1E,$02,$00,$DD,$1A
    07:34.179: (07:34.178)$91,$59,$02,$08,$FF,$30,$DD
    07:34.187: (07:34.187)$20,$58,$9F,$01,$30,$B8
    07:34.203: (07:34.189)$21,$56,$00,$89
    very impressed with the fast response....again many thanks and great site.
    I need to see more of that data, at least 5 seconds.
    It will eventually repeat (every 1 or 2 seconds) and I would like to see at least two complete cylces.
    Feb 2008
    Here's some info from last night, I thought I sent to u!
    If you need more let me know. One thing I did notice is the a/c Compresser on 1 pic says "fail" another pic says "ok".....anyway thanks again for everything!....sorry the screen shots are kind of small........
    Feb 2008
    here ya go found some more data from yesterday
    07:08.187: Ready.
    07:34.267: (07:34.267)$90,$59,$1E,$02,$00,$DD,$1A
    07:34.283: (07:34.269)$91,$59,$02,$08,$FF,$30,$DD
    07:34.285: (07:34.285)$20,$58,$9F,$01,$30,$B8
    07:34.299: (07:34.299)$21,$56,$00,$89
    07:34.363: (07:34.363)$90,$59,$1E,$02,$00,$DD,$1A
    07:34.379: (07:34.365)$91,$59,$02,$08,$FF,$30,$DD
    07:34.395: (07:34.381)$20,$58,$9F,$01,$30,$B8
    07:34.397: (07:34.397)$21,$56,$00,$89
    07:34.459: (07:34.459)$90,$59,$1E,$02,$00,$DD,$1A
    07:34.475: (07:34.475)$91,$59,$02,$08,$FF,$30,$DD
    07:34.491: (07:34.491)$20,$58,$9F,$01,$30,$B8
    07:34.493: (07:34.493)$21,$56,$00,$89
    07:34.523: (07:34.507)$A8,$59,$44,$00,$00,$93,$28
    07:34.525: (07:34.525)$A9,$57,$4E,$21,$91
    07:34.571: (07:34.555)$90,$59,$1E,$02,$00,$DD,$1A
    07:34.573: (07:34.573)$91,$59,$02,$08,$FF,$30,$DD
    07:34.587: (07:34.587)$20,$58,$9F,$01,$30,$B8
    07:34.603: (07:34.589)$21,$56,$00,$89
    07:34.619: (07:34.605)$A0,$55,$0B
    07:34.621: (07:34.621)$A1,$56,$C0,$49
    07:34.667: (07:34.667)$90,$59,$1D,$02,$01,$DD,$1A
    07:34.683: (07:34.669)$91,$59,$02,$08,$FF,$30,$DD
    07:34.685: (07:34.685)$20,$58,$9F,$01,$30,$B8
    07:34.699: (07:34.699)$21,$56,$00,$89
    07:34.715: (07:34.715)$F0,$56,$F4,$C6
    07:34.763: (07:34.763)$90,$59,$1D,$02,$01,$DD,$1A
    07:34.779: (07:34.765)$91,$59,$02,$08,$FF,$30,$DD
    07:34.795: (07:34.781)$20,$58,$9F,$01,$30,$B8
    07:34.797: (07:34.797)$21,$56,$00,$89
    07:34.875: (07:34.859)$90,$59,$1E,$02,$01,$DD,$19
    07:34.878: (07:34.877)$91,$59,$02,$08,$FF,$30,$DD
    07:34.891: (07:34.891)$20,$58,$9F,$01,$30,$B8
    07:34.900: (07:34.900)$21,$56,$00,$89
    07:34.971: (07:34.955)$90,$59,$1F,$02,$00,$DD,$19
    07:34.976: (07:34.976)$91,$59,$02,$08,$FF,$30,$DD
    07:34.987: (07:34.987)$20,$58,$9F,$01,$30,$B8
    07:35.003: (07:34.990)$21,$56,$00,$89
    07:35.019: (07:35.006)$A8,$59,$44,$00,$00,$93,$28
    07:35.023: (07:35.023)$A9,$57,$4E,$21,$91
    07:35.067: (07:35.067)$90,$59,$20,$02,$00,$DD,$18
    07:35.083: (07:35.071)$91,$59,$02,$08,$FF,$30,$DD
    07:35.099: (07:35.090)$20,$58,$9F,$01,$30,$B8
    07:35.103: (07:35.103)$21,$56,$00,$89
    07:35.163: (07:35.163)$90,$59,$1F,$02,$00,$DD,$19
    07:35.179: (07:35.167)$91,$59,$02,$08,$FF,$30,$DD
    07:35.384: Com timeout: Data frame truncated: $20,$FC,$9F,$01,$30,$B8,$21,$56,$00,$89,$90,$59,$1 F,$02,$00,$DD,$19,$91,$59,$02,$08,$FF,$30,$DD,$20, $58,$9F,$01,$30,$B8,$21,$56,$00,$89,$90,$59,$1F,$0 2,$00,$DD,$19,$91,$59,$02,$08,$FF,$30,$DD,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00
    07:35.393: No chatter found
    07:35.399: (07:35.399)$20,$58,$9F,$01,$30,$B8
    07:35.403: (07:35.403)$21,$56,$00,$89
    07:35.467: (07:35.467)$90,$59,$20,$02,$00,$DD,$18
    07:35.483: (07:35.473)$91,$59,$02,$08,$FF,$30,$DD
    07:35.499: (07:35.488)$20,$58,$9F,$01,$30,$B8
    07:35.505: (07:35.505)$21,$56,$00,$89
    07:35.515: (07:35.515)$A8,$59,$44,$00,$00,$93,$28
    07:35.531: (07:35.519)$A9,$57,$4E,$21,$91
    07:35.563: (07:35.563)$90,$59,$20,$02,$00,$DD,$18
    07:35.579: (07:35.567)$91,$59,$02,$08,$FF,$30,$DD
    07:35.595: (07:35.583)$20,$58,$9F,$01,$30,$B8
    07:35.600: (07:35.600)$21,$56,$00,$89
    07:35.611: (07:35.611)$A0,$55,$0B
    07:35.627: (07:35.615)$A1,$56,$C0,$49
    07:35.675: (07:35.659)$90,$59,$20,$02,$00,$DD,$18
    07:35.681: (07:35.681)$91,$59,$02,$08,$FF,$30,$DD
    07:35.691: (07:35.691)$20,$58,$9F,$01,$30,$B8
    07:35.697: (07:35.697)$21,$56,$00,$89
    07:35.707: (07:35.707)$F0,$56,$F4,$C6
    07:35.771: (07:35.755)$90,$59,$20,$02,$00,$DD,$18
    07:35.777: (07:35.777)$91,$59,$02,$08,$FF,$30,$DD
    07:35.787: (07:35.787)$20,$58,$9F,$01,$30,$B8
    07:35.803: (07:35.793)$21,$56,$00,$89
    07:35.867: (07:35.867)$90,$59,$1F,$02,$00,$DD,$19
    07:35.883: Error: Reply frame checksum failure
    07:35.886: No chatter found
    07:35.899: (07:35.891)$20,$58,$9F,$01,$30,$B8
    07:35.905: (07:35.905)$21,$56,$00,$89
    07:35.963: (07:35.963)$90,$59,$1F,$02,$00,$DD,$19
    07:35.979: (07:35.968)$91,$59,$02,$08,$FF,$30,$DD
    07:35.995: (07:35.984)$20,$58,$9F,$01,$30,$B8
    07:35.999: (07:35.999)$21,$56,$00,$89
    07:36.011: (07:36.011)$A8,$59,$44,$00,$00,$93,$28
    07:36.027: (07:36.027)$A9,$57,$4E,$21,$91
    07:36.075: (07:36.059)$90,$59,$1F,$02,$00,$DD,$19
    07:36.082: (07:36.082)$91,$59,$02,$08,$FF,$30,$DD
    07:36.091: (07:36.091)$20,$58,$9F,$01,$30,$B8
    07:36.095: (07:36.095)$21,$56,$00,$89
    07:36.171: (07:36.155)$90,$59,$1E,$02,$00,$DD,$1A
    07:36.176: (07:36.176)$91,$59,$02,$08,$FF,$30,$DD
    07:36.187: (07:36.187)$20,$58,$9F,$01,$30,$B8
    07:36.203: (07:36.191)$21,$56,$00,$89
    07:36.267: (07:36.267)$90,$59,$1E,$02,$00,$DD,$1A
    07:36.283: (07:36.271)$91,$59,$02,$08,$FF,$30,$DD
    07:36.299: (07:36.287)$20,$58,$9F,$01,$30,$B8
    07:36.303: (07:36.303)$21,$56,$00,$89
    07:36.363: (07:36.363)$90,$59,$1E,$02,$00,$DD,$1A
    07:36.379: (07:36.379)$91,$59,$02,$08,$FF,$30,$DD
    07:36.395: (07:36.383)$20,$58,$9F,$01,$30,$B8
    07:36.399: (07:36.399)$21,$56,$00,$89
    07:36.475: (07:36.459)$90,$59,$1E,$02,$00,$DD,$1A
    07:36.479: (07:36.479)$91,$59,$02,$08,$FF,$30,$DD
    07:36.491: (07:36.491)$20,$58,$9F,$01,$30,$B8
    07:36.495: (07:36.495)$21,$56,$00,$89
    07:36.523: (07:36.507)$A8,$59,$44,$00,$00,$93,$28
    07:36.527: (07:36.527)$A9,$57,$4E,$21,$91
    07:36.571: (07:36.555)$90,$59,$1E,$02,$00,$DD,$1A
    07:36.575: (07:36.575)$91,$59,$02,$08,$FF,$30,$DD
    07:36.587: (07:36.587)$20,$58,$9F,$01,$30,$B8
    07:36.603: (07:36.603)$21,$56,$00,$89
    07:36.619: (07:36.619)$A0,$55,$0B
    07:36.623: (07:36.623)$A1,$56,$C0,$49
    07:36.667: (07:36.667)$90,$59,$1E,$02,$00,$DD,$1A
    07:36.683: (07:36.672)$91,$59,$02,$08,$FF,$30,$DD
    07:36.688: (07:36.688)$20,$58,$9F,$01,$30,$B8
    07:36.703: Error: Reply frame checksum failure
    07:36.706: No chatter found
    07:36.919: Com timeout: Data frame truncated: $F1,$F0,$56,$F4,$C6,$90,$59,$1E,$02,$00,$DD,$1A,$9 1,$59,$02,$08,$FF,$30,$DD,$20,$58,$9F,$01,$30,$B8, $21,$56,$00,$89,$90,$59,$1F,$02,$00,$DD,$19,$91,$5 9,$02,$08,$FF,$30,$DD,$20,$58,$9F,$01,$30,$B8,$21, $56,$00,$89,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00
    07:36.923: No chatter found
    07:36.975: (07:36.959)$90,$59,$1F,$02,$00,$DD,$19
    07:36.979: (07:36.979)$91,$59,$02,$08,$FF,$30,$DD
    07:36.991: (07:36.991)$20,$58,$9F,$01,$30,$B8
    07:37.007: (07:36.995)$21,$56,$00,$89
    07:37.023: (07:37.011)$A8,$59,$44,$00,$00,$93,$28
    07:37.027: (07:37.027)$A9,$57,$4E,$21,$91
    07:37.071: (07:37.055)$90,$59,$1E,$02,$00,$DD,$1A
    07:47.611: Stop scanning for chatter
    07:48.676: Check vehicle interface...
    07:48.683: Waiting for Aldl bus silence of at least 50ms...
    07:48.853: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
    07:48.867: Max232 interface detected OK
    07:48.868: Scanning for heartbeat and chatter frames...
    07:48.868: Waiting for Aldl bus silence of at least 50ms...
    07:49.491: Error: Reply frame checksum failure
    07:49.511: Heartbeat frame:
    07:49.511: 07:49.203: $21,$56,$00,$89
    07:49.511: Heartbeat frame is followed by 80ms of silence
    07:49.511: Advisable value for T6 is 40ms
    07:49.511: Chatter frame(s):
    07:49.511: 07:49.283: $90,$59,$1F,$02,$00,$DD,$19
    07:49.511: 07:49.283: $91,$59,$02,$08,$FF,$30,$DD
    07:49.511: 07:49.299: $20,$58,$A0,$01,$30,$B7
    08:01.684: Check vehicle interface...
    08:01.692: Waiting for Aldl bus silence of at least 50ms...
    08:01.865: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
    08:01.879: Error: Reply frame checksum failure
    08:01.888: No response from Max232
    08:01.888: Retrying Max232 detection...
    08:01.888: Waiting for Aldl bus silence of at least 50ms...
    08:01.961: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
    08:01.975: Max232 interface detected OK
    08:01.976: Scanning for heartbeat and chatter frames...
    08:01.976: Waiting for Aldl bus silence of at least 50ms...
    08:02.391: Error: Reply frame checksum failure
    08:02.421: Heartbeat frame:
    08:02.421: 08:02.215: $21,$56,$00,$89
    08:02.421: Heartbeat frame is followed by 80ms of silence
    08:02.421: Advisable value for T6 is 40ms
    08:02.421: Chatter frame(s):
    08:02.421: 08:02.295: $90,$59,$20,$02,$01,$DD,$17
    08:02.421: 08:02.295: $91,$59,$02,$08,$FF,$30,$DD
    08:02.421: 08:02.311: $20,$58,$A0,$01,$30,$B7
  1. Replies: 2
    Last Post: June 2nd, 2010, 05:44 PM
  2. Replies: 1
    Last Post: June 2nd, 2010, 03:56 PM
  3. Newbie to EFILive, Just a Few Dumb Questons
    By EngMach496 in forum Custom Operating Systems
    Last Post: October 15th, 2008, 12:09 PM
  4. Help!!! My EFILive is coming monday!! Newbie!!
    By LS1FREEK in forum Gen III V8 Specific
    Last Post: June 23rd, 2008, 04:04 PM
  5. More newbie help Please...............
    By FreddyG in forum General (Petrol, Gas, Ethanol)
    Last Post: June 27th, 2006, 05:53 AM
