Indicated throttle position verses Absolute throttle postion.
Whats the difference?
SAE.TP is usually reads 88% max, of 0 - 5 volts from the sensor
Does GM.ETCTP indicate the % of the opening of the butterfly? Reads 0 - 100%
I use the SAE.TP with my older PCM (05) and the GM.ETCTP works (0 - 100%) on the new E38 in the 07 Denali. Not sure if this is what you meant, but hope it helps.Originally Posted by Gelf VXR
Ron
2014 Silverado 4X4 6.2L
2010 Camaro 2SS-RS L99
2007 Sierra Denali 6.2L
2005 1500HD 4X4 Quadrasteer 6.0L, COS3 SD
I think the difference is with the ETC stuff, ETC tbs dont have an IAC for idle so the PCM manually cracks the blade for idle. I think my I6 idles at about 8-12% throttle position so subtracting that from 100% gives the 88% you see at WOT. Just use the GM.ETCTP pid though!
SAE.TP works fine (0-100%)on my 05 and it has ETC so it may be other factors at work also.
Hmm interesting. Well then my theory kinda goes out the window...Originally Posted by RonC
