Results 1 to 10 of 18
Thread: Issues with LS7 programming
    Apr 2005
    Default Issues with LS7 programming
    Hi guys, I am hoping someone might be able to shed some light on an LS7 I am working on. It is a stock Z06 with a cam and exhaust (customer isn't sure what cam is in the car). At light load around 1500 to 2000 rpm, the timing is jumping around like crazy....about 8 degrees up and down rapidly. I tried zeroing out the torque reduction stuff, but it appears that it is still somehow active. Has anyone else experienced this? I have attached the log.
    Apr 2005
    I couldn't attach the cal, it's over 1 meg.
    Feb 2008
    Turn off DFCO and CFCO. Also monitor idle adaptive spark. You also need to add more idle airflow. A big cam needs about 15% more air in the lower rpm ranges.
    Jul 2005
    Quote Originally Posted by grfperformance
    you mean less air in low rpm?
    Apr 2005
    This isn't happening in the idle range it's happening at light load driving.
    Jason,
    Posting tune file (.tun): Maximum allowed size 3.9MB
    Posting log file (.efi): maximum allowed size 1MB
    Posting zip file (.zip): maximum allowed size 2MB (compressed)
    You should be able to post the tune file;
    To post the log file, if it's too big compress it to a zip file and post the zip file.
    If you're strill having trouble posting the files, send me a pm.
    Cheers
    Joe
    Apr 2005
    Still no luck attaching the .tun file.
    Try to zip the tune file and see if that works.
    How big is the tune file...?
    Apr 2005
    Nope...won't take that either.
    Can you email it to me, include a link to this thread in the email...
    My email address is in my profile (click on my username to the left of this post, select Send email to joecar).
  1. Programming the DIC
    By Whippled 496 in forum Tips and tricks
    Last Post: December 14th, 2012, 04:44 PM
  2. programming LC-1
    By z06ufgrad2002 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 18th, 2009, 10:22 AM
  3. Need Help Re-Programming The BCM
    By cwksf in forum General
    Last Post: July 26th, 2009, 03:05 PM
  4. Transmission TCM programming...
    By serpa4 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 20th, 2007, 04:05 AM
