Results 1 to 9 of 9
Thread: In gear Idle issues....
    Junior Member LPDTuning's Avatar
    Feb 2008
    Default In gear Idle issues....
    Hey guys. Im new here and just got EFI a few weeks ago. Im having some issues with a truck I'm tuning. While at an idle in gear, I have a lope. I didnt change any fuel pressure at idle or any pulse width. (So I thought) I did some logging to find that at idle im demanding 4900psi but was fluctuating from 52-4700psi. So, I went into my pulse width chart and started lowering the values from the 5 mm3's all the way up to 0 over to 40MPa. And I still had a lopey idle. So, I looked at the scan tool, and moved the line around on the graph and noticed that it was highlighting the 190MPa column in the the injection pulse chart. Why is that? Is the CP3 getting weak and the valve is opening all the way to keep pressure? So, I lowered those values and it still lopes. But, load up the stock tune and all is good. I have a tune in my truck that has way more fuel in the same areas, and it idles smoothly. Im learning a lot but there is so much more to go. Thanks in advance for any help.
    -Danny-
    "Napalm"........'03 LB7 Ext Cab 2wd, Spiral Grey Metallic, lowered, Fuel Rampage wrapped in Nitto 420S, Stainless Diesel S475 5-Blade over stock.
    Mar 2007
    Sounds to me like you changed a low end pulse width. That is what caused my lopey idle.
    Feb 2008
    Thats exactly what I did. I knew I did, but in my logging I had a units conflict and it was logging the wrong area in the pulse width table and I was changing the wrong end of the table. Needless to say I got it fixed. Thanks!
    -Danny-
    Mar 2007
    Glad I could help.
    Junior Member Jared Duramax's Avatar
    Feb 2008
    i have the same issue with one of my tunes but i only get a lopy idle when its cold out. so i got a lift pump for the truck and that made me have a lopy idle all the time.
    Jared
    2003 GMC Sierra 2500HD LB7
    285/75R16 BFG AT, Prodegy brake controller, Bilstine Shocks, Tierod sleves, Pitman and Idler supports, 5" Magnaflow Turbo Back, PPE Boost Valve, Phantom II Boost and Pyro on Pillar, BD Manifold. EFI LIVE V2 By SoCal, EDP Twin Lift Pump's, Suncoast IV 1056, Billet Input Shaft, Merchant Automotive Pump Rub Kit
    Member #3 of NC Dmax's
    Sep 2006
    Quote Originally Posted by Jared Duramax
    Which lift pump did you install?...Too much pressure to the CP3 and it will start to surge...I had this problem using a Holley Black pump on a LB7...
    2007 CC/SB 4WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SD Sleeves, SoCal Diesel
    2002 CC/DRW 2WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SoCal Diesel
    Feb 2008
    i put that PPE pump on that you helped me with the wiring on. i turned the pressure down all the way it helped but it didnt eliminate it.
    Jared
    Jared
    Sep 2006
    Sorry, apparently I've got short-term memory issues
    Have you called PPE yet?
    Feb 2008
    Yup and i went through it with Dan but im just guessing its in my tuning and i need to adjust my idling tables.
    Jared
    Jared
  1. idle issues...
    Last Post: May 8th, 2010, 10:11 AM
  2. Car is too rich at idle in park / perfect in gear
    By exploder in forum Gen III V8 Specific
    Last Post: December 3rd, 2008, 12:59 AM
  3. Idle Issues
    By RacerChris in forum Gen III V8 Specific
    Last Post: June 11th, 2007, 05:39 PM
  4. Surging idle issues - please help!
    By tunedportcj5 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 22nd, 2006, 01:41 PM
  5. a couple idle issues here.
    By BACKinBLACK in forum General (Petrol, Gas, Ethanol)
    Last Post: May 20th, 2006, 01:17 AM
