I think it would be nice if EFI live could control the fans to turn on at a certain transmission temperature as well as Engine Temperature. What do you guys think?
Why? is your tranmission cooled by the engine cooling system
Most 4x4's like mine have a tranny cooler located in front of the radiator. Although I may have to hook up my transmission to the radiator for extra cooling...Originally Posted by Happy Jim
Actually only (some) fullsize guys get the external trans cooler, the mid size guys (like me) have the trans cooler integrated into the radiator (absolutely greaaat for cooling). This would be cool to have, that way the trans cooler can get more airflow and cool the trans down.
I have this too. On most chevy pickups and SUV's (fullsize), it will flow through the radiator then to the external cooler, then return back to the transmission. Some argue that this design isn't that great, because if you overheat the engine it could overheat your tranny, and vice versa. Either way, my transmission gets hot before my engine does, and I think it would be nice to have the PCM control that...Originally Posted by ScarabEpic22
I don't think any of the PCM's/OS's have separate outputs/tables for trans fan control...
Mine used to...then I put an external trans cooler in after the radiator (similar to your setup). Much lower and stable temps, even after a long hard driving session I dont see elevated temps and on the hwy while towing they are much more consistent.Originally Posted by MrZ71man
