So I want to start the post off with thanking the staff at EFI Live, and Ira at Fish tuning. My V2 FS unit was not communicating to any computer I attached it to. The got me a new V2 unit overnighted to my place, and everything works flawless!!! Thanks to you guys.....
Main Specs:
2007 TBSS
E67 computer
AWD
Mods:
CNC Ported L92 Heads
L92 truck intake
Comp Cam (on the mild side)
Kooks Long tubes
Kooks Catted Y pipe
Magna Flow cat back
52lb injectors (may get blower in future)
Issues at have me baffled:
1. Creeping LTFT on both banks at idle
2. Very lean LTFT on areas of high vacuum while off the throttle
3. Hard to start when dead cold mornings (20-30 degrees F) (mostly fixed)
I have listed those issues in order of importance. And have spent about a week scratching my head as to why this thing does the couple funky things that it does. I have edited the VVE tables all over the place in the areas that I am having issues with....yet it keeps coming back.
Example, say it says its adding 15% fuel at idle. I make the changes to the VVE, save and load the file..... starts off fine, then about 15min later, the trims creep right back to the 15% number. So no matter how much correction I make to the VVE either positive or negative.... I see no change. (In those areas, other areas are fine)
Now, about the areas when I am in high vacuum and no load, with my foot off the gas. I find it odd that even in these tables it registers a LTFT. Shouldn't it know that I am off the gas and not to be making a correction in these tables?
Cold start. Well, that one was really kicking my butt. But I think I have it licked after I found a LOT of very odd tables, and values in a lot of the stock programing for this E67 computer. But I have to let it get back down to 20-30 degrees F to verify the changes I have made. Today it was fine but it was 38 degrees F here, which is mild for right now. Some mornings it's 14 degrees F, in the early AM.
Anyone have issues like this on one of these E67 computers?
I am attaching a image of my log file, and using a key identifying my zones.
Purple Circle = Idle area
Blue Square = No throttle, coming to a stop
Black Square = No throttle, coasting down hills or the highway.
