Results 1 to 9 of 9
Thread: new to efi live
    Dec 2007
    Default new to efi live
    I'm new to efi and need help.I want to put a tune in a buddys truck.It's an 07 6.0l 4l80e.the tune here makes the truck run like an electric fork lift.no throttle at all.would appreciate any and all help..thanks
    Jan 2005
    What modifications have been made to the engine? What are you trying to achieve with the tune? How does it run with th estock tune?
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Unknown Zone TAQuickness's Avatar
    Jan 2005
    Welcome to the forum ilov2xlr8!
    And electric fork lift doesn't sound good. We should be able to help get you on your way, but as dfe1 has pointed out, we will need some additional info.
    Dec 2007
    Default tun
    Quote Originally Posted by dfe1
    it runs great with the stock tune.we are trying to get better millage out of the truck.it is 100%stock with about 5700 miles on it.now he is getting about 8.5 mpg,on stock tune.I would like to see more power across the board,low throttle,&wot.thanks a million!!
    Oct 2006
    Man those 6.0L in the trucks get lousy gas mileage .
    These guys on here will get you straightened out in no time though .
    Aggressive DFCO helps some .
    2006 Trailblazer
    Dec 2007
    anyone?
    Jan 2005
    Everything looks reasonable in the tun file you posted. I changed the DFCO settings to bring it in quicker. Give that a try and see if it helps. Also, smooth out the VE table and monitor the long term fuel trims-- make sure they stay between 0 and -4%. Once you get that done, play with the timing at cruise and idle. You might also experiment with shift points. The curves look decent, but I don't know what kind of load the truck is under during light accel.
    678/344-1590
    Dec 2007
    thank you very much,I'll keep you posted on how it does,when the truck gets back to ohio from flordia
    Dec 2007
    Default back from flordia
    table b6614 copied &paisted ,runs like a raped ape thanks for yall help!!!
    Quote Originally Posted by ilov2xlr8 View Post
  1. Thanks EFI Live
    By JOHNBOY in forum General (Diesel)
    Last Post: April 1st, 2010, 08:16 AM
  2. New To EFI Live
    By Mike Miller in forum Duramax LB7
    Last Post: July 23rd, 2008, 09:22 AM
  3. Efi live on the way
    By 04llygmc in forum Duramax LLY
    Last Post: March 5th, 2006, 05:21 AM
  4. Live tuning for RFI-Live??
    By Bob's Garage in forum General (Petrol, Gas, Ethanol)
    Last Post: September 14th, 2005, 05:27 AM
