Page 14 of 17 FirstFirst ... 41213141516 ... LastLast
Results 131 to 140 of 167
Thread: Auto Tuning - Step-by-Step
  1. #131
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    Quote Originally Posted by ZL1Killa
    if you want an AFR of 14.63 you set your PE based on rpm table to 1.00
    here is an attached excel sheet of some AFR's for ya, its a zip file but if you can't unzip it send me your email address
    My PE based on RPM is set to this:
    LABELS PE Modifier Based on RPM (AFR)
    RPM {link: SAE.RPM} Value
    0 13.037127
    400 13.037127
    800 13.037127
    1200 13.037127
    1600 13.037127
    2000 13.037127
    2400 12.913499
    2800 12.781279
    3200 11.822935
    3600 11.822935
    4000 11.822935
    4400 11.822935
    4800 11.822935
    5200 11.822935
    5600 11.822935
    6000 11.822935
    6400 11.822935
    6800 11.822935
    7200 11.822935
    That is Stoich for my turbo setup. Does that help? Once you are in PE, the A/F goes by this table. If I wanted it 14.6, I'd simply set it at 14.6 but I need RICH when I go PE (WOT).
    Elmer
    2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
  2. #132
    Senior Member WicketMike's Avatar
    Nov 2003
    Quote Originally Posted by eboggs_jkvl
    0 13.037127
    400 13.037127
    800 13.037127
    1200 13.037127
    1600 13.037127
    2000 13.037127
    2400 12.913499
    2800 12.781279
    3200 11.822935
    3600 11.822935
    4000 11.822935
    4400 11.822935
    4800 11.822935
    5200 11.822935
    5600 11.822935
    6000 11.822935
    6400 11.822935
    6800 11.822935
    7200 11.822935
    Elmer
    im getting my turbo installed next week and ill shoot for those numbers in the pe. but what are you doing for part throttle? are you still shotting for 14.63 at part throttle?
    98' White TA A4 TSP 231/237 PP Stage II 59cc heads
    401rwhp (unlocked) 1.594 60'-11.60 e.t.-116.98 mph
    98' Sport Gold Metallic TA M6 - 13.39 e.t. Bone Stock
    My Trans Ams
    2006 Chevy Monte Carlo SS 5.3L LS4 (wifes car) stock (for now)
  3. #133
    Apr 2004
    14.6 is what the PCM is supposed to be thrashing about and getting me.
    Elmer
  4. #134
    Junior Member ws6togo's Avatar
    Mar 2005
    Quote Originally Posted by 87gmc
    I just used auto tune this weekend all i have to say is sweeeettt 8)
    Where is the auto tune function??
    '00 Pewter TA WS6 12.6@111 on street tires 1.87 60'
    PERFORMANCE: BG Ram Air, Lid, K&N, MSD 8.5 wires, NGK TR55's, 160*
    SUSPENSION: BMR-STB/SFC/PHR, UMI LCA's
    DRIVETRAIN: rebuilt 4L60E. 3000TCI, Hayden Trans Cooler, Yukon 3.73's, TA girdle
    TUNING: EFILive
    No runs after engine upgrade
    Newest mods:LS6-intake/heads/ported oil pump, 28lb injectors, Comps-918's, Comps 224/230 .581/.592 114 cam, Dynatech LT's, Rollmaster chain.
  5. #135
    Jan 2005
    Quote Originally Posted by ws6togo
    Go back to post #1 of this thread
  6. #136
    Oct 2003
    Quote Originally Posted by TAQuickness
    Do Not go past GO. Do Not Collect $200.
    joel
  7. #137
    Lifetime Member ZL1Killa's Avatar
    May 2005
    0 13.037127
    400 13.037127
    800 13.037127
    1200 13.037127
    1600 13.037127
    2000 13.037127
    2400 12.913499
    2800 12.781279
    3200 11.822935
    3600 11.822935
    4000 11.822935
    4400 11.822935
    4800 11.822935
    5200 11.822935
    5600 11.822935
    6000 11.822935
    6400 11.822935
    6800 11.822935
    7200 11.822935
    Elmer
    sorry about that, I haven't changed my view to AFR from the options, I'm still using the original
    01 T/A WS6 #4984 STOCK 342HP and 352TQ [/b]MODS:Too many to list, PM...funny rear mount.. father/son build.
    [Quote :ur car is sneezing!!!!]
    I KNOW KUNG FU.
    My STS build: http://www.ls1tech.com/forums/showthread.php?t=631954
    453HP 475TQ @6psi
    .....CAM'd, IC'd, and 7psi'd #'s coming.....
  8. #138
    Dec 2017
    I am new to efi live and trying to idle tune and set some parameters with out a wideband 02 sensor. I have read several posts but get confused as there is conflicting info. This is a 01 5.3 with flat top pistons and an asa cam with a 60e trans with a 2500 rpm stall with 36 lb bosch injectors which are 42 lbs at 58 psi. I have scaled the injectors and copied the tables from the 2000 asa Camaro tune. The truck will start and run cold but die when warming up. Also idle will surge in gear when warm. I have driven the truck a short distance. Also when starting black smoke out tail pipes. Any help be greatly appreciated
  9. #139
    Hi Builtyodas,
    welcome to the forum
    are you running a MAF...?
    Post your current tune file, and the stock 5.3 tnue file.
  10. #140
    Dec 2017
    Joe car I sent you an email also if you could help me greatly appreciated running out of time to get this truck done
  1. ** Next Step? **
    By Nemo in forum Duramax LLY
    Last Post: February 15th, 2009, 04:56 PM
  2. BBL Step by Step Tutorial ?
    By JR-CRUZN-C5 in forum FlashScan V2 BB Logging
    Last Post: June 29th, 2008, 10:28 PM
  3. 2 step
    By minytrker in forum Custom Operating Systems
    Last Post: July 16th, 2007, 01:01 AM
  4. step by step torque managment,speed limiter,efan,engine torq
    By 5.3 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 24th, 2005, 10:12 PM
  5. SD Step by Step
    By mistermike in forum General (Petrol, Gas, Ethanol)
    Last Post: June 28th, 2005, 02:21 PM
