Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Filtering Data
    Oct 2003
    Default Filtering Data
    Let's say I have a Log file X and I'm using the "BEN factor-FJO/Autotune" map with my FJO Wideband. I have the "Empty Cell" = 50.Open Loop SD tune.
    Now I want to filter :
    1.)All noncell 22 data -i.e. All FTC Cell data less than 22 (Open Loop all decel is cell 21 and idle is cell 20).
    2.) All TPS transients greater than 5% per 100 msec.
    Both filters are setup. Can I do 2 passes of the logged data in sequence - one of each filter ?? Will this reliably filter out all decel, idle and transient data?
    joel
    Jan 2005
    If I understood your question correctly, no. You will need to set up one filter that will filter All noncell 22 data -i.e. All FTC Cell data less than 22 OR All TPS transients greater than 5% per 100 msec
    It's similar in format to the filter screen shot in the autotune doc
    Oct 2003
    Thanks.
    I set up the filters. My question is can I run the logged data , for a given map (BEN map), sequentially through both filters. Basically two passes of the same logged data filtering out the FTC cells and the Throttle transients.
    joel
    Jan 2004
    Not that I am aware of. If you want to filter out the data you can either do both, or one or the other. From my understanding and use, you can't apply one filter over the other. Only way is to combine both filters into one. What are you trying to do joel?
    Oct 2004
    I have just read the original post in this tread, and it may be the most interesting post I have read since starting the Auto-Tune process.
    I just want to clarify something though...
    I just logged the FT Cell# on my drive home. I had never noticed the behaviours of these cell #'s (20, 21 & 22).
    The cells to me see to represent the following (although this is observed from a single log session):
    Cell 20 - Idle, but also when still decelerating
    Cell 21 - Deceleration, but also when coasting at steady or non aggressive throttle position
    Cell 22 - When the throttle position is increased, accelerating, or perhaps under increased load
    Firstly, does that sound correct?
    Secondly, why would you want to exclude cell 22 in this case? I was thinking I'd want to drop cell 20?
    I'd appreciate your comments...
    Andrew
    EFILive Crew
    Jan 2004
    You wouldn't want to Andrew, it says NONCELL 21. He is wanting to remove all cells below 22, not including 22.
    Oct 2003
    black02ss, Tordne and TAquickness - FTCs 20 and 21 are "nonload" cells and are used during idle and deceleration - when I'm in open loop.By "nonload" I mean when the engine is not under a load. We want to exclude "nonload" data, from the BEN/VE process, for accuracy.
    We want to exclude throttle transients (Non-Steady State) for accuracy also. The AFR changes substantially during transients as the PCM adjusts for changing conditions.
    I just want to filter out the garbage
    joel
    Jan 2004
    I understand what you are wanting to do bink, I might have worded my response to Tordne wrong. I have been thinking about this as I had forgot about FTC's when I got rid of Edit. How much of a swing are you seeing on decel? If I don't have decel in mine, then there are some cells at low kPa that I can't hit. I am going to add FTC's to my log on the way home to see how much of an impact it has. I'll post my results shortly.
    FWIW you can apply two filters sequentially.
    Create a filter with the first criteria only, apply it and then select File->Save as and save the log file with a new name. That will save *only* the visible frames.
    Then create a second filter and apply it to the saved data which contains only the visible frames from the first filter.
    Jan 2004
    I have posted 3 images. Each image shows the difference in one log file from the effects of decel and idle. From seeing this, I personally would use all three due to the fact I think idle(FTC 20) is needed for a good BEN at that MAP, decel(FTC 21) only appears to effect my car from MAP 30 down. If I didn't have that, I don't see how I could tune "some" of those cells. What do you guys think?
ID:	147   Click image for larger version.
ID:	148   Click image for larger version.
  1. AD filtering question?
    By 67SS509 in forum General
    Last Post: November 16th, 2009, 03:24 PM
  2. L92 Data log
    By etmotorsports in forum Gen IV V8 Specific
    Last Post: January 26th, 2008, 05:04 PM
  3. Filtering DFCO Cells
    By Tordne in forum General
    Last Post: June 27th, 2007, 02:18 PM
  4. Tuning without IAT Data
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: June 14th, 2006, 01:14 PM
