Hi, I have a couple of question.
I have the PLX wideband.
Using the AD input and the AD gauge in the scanner you read the AD voltage 0-5.
Now, using the formular from PLX VX2+10=ASR
Can a gauge be created to read AFR?
Max"Ing the values in B4205 and disabiling B4206 and changing the comanded fuel in B3601 to 15.40.
I am running 15.40 in open loop.
How can I get my PE back.
Did it lean out as well or does it not work under PE.
Wolfie
