It has to be a automatic trans. There are not any in the stock tune files
Thanks for any help
Thanks for any help
There is not a stock auto Z06. All Z06's were 6 speeds from GM.
HMM..... anything with a ls6 automatic ?
Just take a 2004 A-4 C-5 and merge the tune, leave the tranny stuff alone and import the LS6 data using the compare function. The Caddy's may be a Automatic LS6
1999 C5 A-4 Convertible
1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
Maine USA
I was told the Idle tables were different because of the stick ... But it looks like im running out of options .
ohh and the caddy's were all stick's to
do what beer said...
01 Z06, 4L60E CONVERSION, L92/L76 TOP END, 72# LS3 INJECTORS (THANKS FIC), DRY NITROUS, COS5
What exactly are you trying to do? Im sure myself or someone on here can help.
Well I installed a 05 ls6 in my 04 silverado and wanted to use the ls6 air flow and spark tables but was told that I needed to use one from a car with an automatic trans. I was told there is diffrent provisions for idle on car with sticks (not sure if that is true or not )
