Results 31 to 37 of 37
Thread: Wideband serial update
  1. #31
    Jul 2010
    boots up ,,, within 3 seconds shows
    scan tool
    tune too,
    diagnostics
    options
  2. #32
    Ok, now start the Scan&Tune software, goto F6 Device Settings, goto F8 Serial IO tab, set Com Port to Wideband, set Wideband to Innovate, Save [to file], Program [into your V2], exit from Device Settings.
    Now connect the LM-1 to V2 via the supplied serial cables joined using a null-modem adapter (or a cable made like this)... it specifically has to do the "null modem" Tx/Rx wire swap...
    Power up your LM-1, your V2 should show the AFR/Lambda/eqr (dive down the menus to the right screen).
    If you want to do BBL/BBR, then in S&T goto F5 Black Box Settings and set up the pidlists/pids/PCM/TCM on the Scan Data tab, and set up the PCM on the Tune Data tab (if you have manual trans leave the 2nd controller blank).
  3. #33
    Jul 2010
    Why do they make this so complex,. Pids and files save here update that,. I love my motec! Thanks joe i have wasted your time lm1 is frozen im ready to smash it to peices, i cant win. I got the plx out now trying to figure a cable out for it is there a way i can use it without that stupid chip on serial port. Which i cant find anywhere. ?
  4. #34
    Oct 2004
    Without the serial modification to the PLX device you can use it with the 0-5 volt A/D input on the FlashScan device. The downside of course is the more complex wiring, and more importantly the less accurate readings.
    You have probably spent the money already, but these are the devices that are serially supported (http://www.efilive.com/index.php?opt...138&Itemid=143). I personally have 2 x LC-1 controllers, but I'd probably go the TechEdge route next time...
    Here is a thread on the serial mod for the SM-AFR (http://forum.efilive.com/showthread....Serial-upgrade).
    Andrew
    EFILive Crew
  5. #35
    Nov 2006
    JAW
    Website: Unknown
    http://14point7.com
    LC-1 WBO2
  6. #36
    Oct 2004
    Thanks for that . Have updated the page now, and am adding the ECM and Zeitronix a well which are supported.
    Andrew
    EFILive Crew
  7. #37
    Jul 2010
    thanks all !!!!!!!!!!!
  1. Serial Wideband AFR & B3601
    By WeathermanShawn in forum General (Petrol, Gas, Ethanol)
    Last Post: April 25th, 2010, 05:51 AM
  2. log serial wideband
    By b18cls1 in forum Black Box Logging
    Last Post: February 12th, 2010, 04:46 AM
  3. Can't log serial wideband anymore
    By white01ss in forum Tutorials
    Last Post: October 28th, 2009, 09:39 AM
  4. serial wideband
    By articSS in forum Black Box Logging
    Last Post: December 19th, 2008, 07:04 AM
  5. Serial wideband.....CAN or RS232?
    By Redline Motorsports in forum FlashScan V2
    Last Post: September 10th, 2008, 03:00 AM
