Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 86
Thread: I made a cable for BB Logging
  1. #51
    Oct 2003
    You do not need to make one. All you have to do is use the genderchanger with null modem capabilities...
    Making the cable is optional and its for simplicity. I am using an LM1.
    Thing is... sadly i have to use 2 cables :S the serial one from the lm1 and the one i made, i wish that the lm1 had the serial db9 connector.
    I am using the LM1 for my WO2. If I use the null-modem male/male adaptor to connect the LM1 serial output to FS2 cable will the output be the same as in the LM1/logworks. I just want to know what I need to change in the LM1 software if anything. Thanks, Jim
    08 Z06
  2. #52
    Jim,
    You don't need to change anything in the LM-1/LC-1... the serial afr is emitted on the serial output regardless of how the analog outputs are programmed.
    Joe
  3. #53
    Oct 2003
    Jim,
    Joe
    Thanks Joe, That will make it easy. Jim
    08 Z06
  4. #54
    Junior Member jomobco's Avatar
    Aug 2007
    I want to make sure I understand this and I'm going to do this right. Use the LC-1 2.5mm to serial cable which was included in package with LC-1. Get a male serial cable to RJ-11 adapter and wire accordingly to schematics shown in this thread. Plug RJ-11 from serial adapter to V2 input next to RJ45 cable on V2 unit. I can now log in digital instead of analog?
    Thanks,
    John
  5. #55
    Quote Originally Posted by jomobco View Post
    Thanks,
    John
    Yes.
    The RJ12 to female 9 pin serial cable is included with your EFILive purchase.
    The null modem male to male adapter that can be used between the LC-1's cable and FlashScan's cable can be purchased here:
    http://www.sfcable.com/cable/p/30D1-C1-S.html
  6. #56
    Should say:
    Plug RJ-11 from serial adapter to V2 input next to USB socket on V2 unit
  7. #57
    Aug 2007
    I couldn't find a male2male null modem locally but I did find a RS232 adaptor DB9M/RJ12F such as this:
    http://www.firstcable.com/newproduct...roupcode=I4799
    First question I guess is will it work? I've read you need a resistor but I'm not understanding why that's the case. For instance if you had snipped off a 2.5mm plug as it appears some have done and wired it directly to a RJ12 there is no resistor is there?
    So I've wired it so that if you're looking at the DB9 Female from the LC-1 with the 5 rows at the top and four on the bottom and you number them left to right top to bottom female hole 3 (I believe DB9 hole 3) is the 2.5mm tip, female hole 4 (DB9 hole 2) is the center of the 2.5mm pin and female hole 1 (DB9 hole 5) is the base of the 2.5mm pin. I've wired my RS232 accordingly but what should I do with the extra 3 wires on it?
  8. #58
    Maybe this diagram will help:
    http://forum.efilive.com/showthread....1088#post71088
  9. #59
    Aug 2007
    That's an excellent diagram. Thank you! So the extra wires I can just tape off and i'm golden? No more trying to get the correct analog voltage?!?! I can't wait!
    Edit: Now I see why the Null Modem comes into play. Even thought I've got male/female connections I've got male securing screws on both sides so only friction or duct tape / zip ties will hold them together.
  10. #60
    Yes.
    I've never screwed the cables together when testing and the friction is plenty strong enough to hold them together. I don't think the null modem connector I linked to has screw receptacles in both sides anyway.
  1. The monkey made me do it.
    By mr.prick in forum Lounge
    Last Post: September 12th, 2009, 02:02 PM
  2. now I know I made the right choice
    By limited cv8r in forum Lounge
    Last Post: November 21st, 2007, 05:40 PM
  3. Just made an interesting find
    By shakinlm7 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 5th, 2007, 11:59 AM
  4. Made 751 Rwhp On Only 14 Psi Thanks To Efilive!! Vid!
    Last Post: June 7th, 2006, 02:59 PM
  5. Anyone made a custom mpg (or km/L) PID?
    By thunder550 in forum General
    Last Post: May 17th, 2006, 04:38 AM
