Serial LM Programmer.. the round one... I will see if I can find that round part so that i can make it
It's a mini-din 8 connector. I will by one that goes straight from the WB to the scan tool. I take it your scan tool is displaying your afrs correctly and accurately.
What is your calibration in LM programmer 1.00V_10.00afr, 2.00V-20.00afr?
On the analogue jack for the LC1 wouldn't running both analogue 1 and 2 voltages be pointless. In the LM programmer the 1st output is for a narrow band and the second is for w/b display. Only one is required. That means only 2 wires are required the output wire and ground.Originally Posted by Blacky
This serial connection is not reading the analog voltages, it's reading the digital AFR from the LC-1's serial port.
For asynchronous serial comms you need 3 wires: Tx, Rx, Gnd.
Pin 1.......TXD
Pin 2.......RXD
Pin 5.......Ground
Ive found the PLX just needs
Signal Ground
TX
Because there is no handshaking and it requires no data to be sent to it.
Makes sense.Originally Posted by JezzaB
