Hi everyone!
I have a question for the people out there who have done an Autove on their boosted cars.
I have a single turbo stroker which is already well tuned but I am wanting to run the Autove through my tune just to refine the main and boost VE's. I am running COS3 and I have a PLX SM_AFR wideband.
The question I have is what values should I run in B3647? The tutorial commands around 12.95 at WOT which I would think is based for a NA application. Should I change these values to a richer mix such as 11.90? as PE isnt used during the Autove exercise.
Also, with B3647 (commanded fuel vs rpm), the KPA only goes to 100 so what happens to the mixtures when your car runs into boost? (anything over 100kpa) Does it use the value from the last column (100kpa) and carry that value throughout the boost range? If so, I am wondering why B3647 doesnt have a MAP range which extends to 285KPA like the boost VE table does?
Any help would be apprectiated
