Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Scan and Tune link problem
  1. #11
    Member Big D's Avatar
    Aug 2007
    Quote Originally Posted by ds8
    Sounds like you need to add the PID, rows and columns you want linked to the cal_link.txt file. My cal_link.txt file for 7.5.3 doesn't have any links for the LL8.
    DS
    This is a good possiblility. Is there a specific file for the LL8?
    Big D, what vehicle is this on...?
    2005 Trailblazer, LL8 Engine, 4.2 L6 MFI
    Has anyone taken a look at the tune and scan files I offered to see if there is any inconsistancy with those?
    What I do find odd is when using B0918 for example, the left parameter is "RPM" and the top parameter is "vacuum kPa". Typlically what I have seen is will for the most part, display the parameter name like "SAE.RPM".
    If anyone wants to see more data logs, let me know and I can send you those.
    Thanks for the help so far guys.
  2. #12
    Oct 2006
    Quote Originally Posted by Big D
    There is only one cal_link file. Mine is located here: C:\Program Files\EFILive\V7.5\Configuration
    If you want the link to work, you have to go into that file and add the necessary items to the LL8 section. Open that file and take a look. LL8 is there, but without links.
    DS
  3. #13
    Aug 2007
    DS
    This is what I see:
  4. #14
    Aug 2007
    whoops, forgot the attachments
  5. #15
    You have to know what PIDs you want to link into what table, and if it linsk to a row or a col...
    Then edit that file and insert a line that looks similar to this (with your PID and table of course):
    B0101.ROW=SAE.RPM
    This example line links SAE.RPM into the B0101 table.
  6. #16
    Aug 2007
    B0101.ROW=SAE.RPM
    When I saw he LL8 was empty, I had a feeling I was going to have to do this. Thanks for the info Joe, I'll get back to you and let you all know how it turns out.
  7. #17
    Awesome, Ill look into this probably tomorrow with my 02 LL8. Ive really wanted to get this working, might be able to get a better idea of what my LL8 really wants vs what Ive given it via tuning.
  1. Scan problem
    By voda1 in forum Gen III V8 Specific
    Last Post: May 24th, 2010, 05:49 AM
  2. Scan problem
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 15th, 2008, 03:12 PM
  3. Scan tool problem NEED HELP
    By yellowC6ohio in forum Gen IV V8 Specific
    Last Post: April 7th, 2008, 04:11 PM
  4. Problems with upgrading V2 from scan only to scan and tune...
    By DngrZne in forum General (Petrol, Gas, Ethanol)
    Last Post: November 26th, 2006, 03:41 AM
  5. odd problem between the tune and scan programs
    By MSGHUFF in forum General (Petrol, Gas, Ethanol)
    Last Post: August 12th, 2006, 04:54 PM
