Results 1 to 6 of 6
Thread: Logging LMM's
    Feb 2008
    Default Logging LMM's
    Ok, maybe i missed something here. I can connect, see real time date, but I cant log the data.......any idea what I am doing wrong?
    Some ideas:
    - Did you select pids on the PIDs tab...?
    - Did you press the red button (record)...?
    Feb 2008
    I did select PIDs, and I see real time data for the PIDs that I select, but the red button is not active?
    Did you:
    - select the right controller type...?
    - enter your VIN and OS id...?
    I pm'd tech support.
    After connecting, how do you view real time data?
    Did you press the yellow button? If so, that will display real time data but not log it. i.e. it starts "logging" but with the pause button pressed so nothing actually gets recorded.
    To start logging, either:
    1. Press the pause button to unpause logging,
    or
    2. Press the red button instead of the yellow button.
    The red and yellow buttons will not be enabled while data is being logged or monitored. Once you click on stop (blue square) the red and yellow buttons will be re-enabled.
    Feb 2008
    WOW, I feel like an ..............
    Anyways, thank you.
  1. Logging L76
    By JezzaB in forum Gen IV V8 Specific
    Last Post: June 11th, 2007, 11:10 PM
  2. VE after logging
    By Beer99C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 15th, 2006, 01:28 PM
  3. Logging RPM
    By oztracktuning in forum Black Box Logging
    Last Post: January 20th, 2006, 06:55 PM
  4. I have a few Q's about logging.
    By SmaknSS in forum General
    Last Post: December 1st, 2005, 06:33 AM
