Results 1 to 6 of 6
Thread: Transmission shifting / Rev limiter
    Apr 2007
    Default Transmission shifting / Rev limiter
    I am tuning an 02 Camaro, The car has a 4000 RPM stall converter and hit the rev limiter before it shifts 1-2, so I put the rev limiter to 6800 RPM and changed the shift point 1-2 to 6200, but I still hit the limiter? Why? Should I just keep lowering the shift point?
    98 WS6, M6, 02 PCM, CO3, SD 2 Bar tune, 416 D1SC Procharger, 73# Injectors, Patriot Lq9 heads, 232 int 240 exh. Lift .595 int .608 exh 115.. header, Intake, AEM WB.
    Aug 2006
    You need to meet 2 conditions for the shift. RPM and MPH. Try raising the wot shift MPH a little.
    Aug 2005
    Quote Originally Posted by Lextech
    I think you've got it backwards there Jeff. With a loose torque converter, you need to adjust the MPH condition down, as there will be more tcc slip causing RPM to be higher.
    Apr 2007
    Thank you..I found out after the fact that there was a gear swap.....that did it
    Aug 2006
    Justin,
    You're absolutely right. I didn't realize my mistake until your post.
    Zapp,
    Sorry bout that.
    Apr 2007
    No problem, once you put me in the direction I knew what you meant
  1. 4x4 shifting
    By southern in forum Gen III V8 Specific
    Last Post: May 18th, 2010, 11:13 PM
  2. 6.2-6sp shifting issues
    By ChrisNJ in forum E37, E38 & E67 PFI ECM's
    Last Post: February 19th, 2008, 12:43 PM
  3. LS1 PCM Performance shifting
    By Cougar281 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2008, 02:31 PM
  4. 2-3 not shifting
    By ASSAMI in forum General (Petrol, Gas, Ethanol)
    Last Post: March 6th, 2007, 11:43 AM
  5. Firm shifting
    By ALRAJHI in forum General (Petrol, Gas, Ethanol)
    Last Post: September 12th, 2006, 02:00 PM
