This is my first large cam, I got the car to idle, but it likes the 17 AFR range.
It is an 02 camaro with headers and a 231 237 / 592 602 at 112. If I try to richen it up it idles bad and stalls when put in gear, as long as it is lean it idles actually, well......nice. the AFR goes to normal as soon as you touch the pedal even in park. Is this normal? or do I have more work?
Thanks....
