Results 1 to 9 of 9
Thread: Ok some serious issues
    Jul 2003
    Default Ok some serious issues
    I made the mistake of starting the scantool (connecting with the green button) while the efilive explorer was on... Now i cannot connect using the scantool and the software hangs everytime I try.
    it hangs so bad that task manager cannot terminate the process and only a reboot will kill it.
    Been trying to get the EXT PIDS as valid and the only way thus far is to open a scanlog recorded by BB to have them marked valid... At that point since i had the efilive explorer on.. connected.. and booooommmm.... my laptop is smoking!!! jajjaa.. j/k
    Ideas? suggestions?
    Feb 2006
    Maybe uninstall and reinstall the software. Do you have another PC to test with?
    Al
    Jul 2003
    Exactly what i just did... uninstall.. WIPE OUT... clean with other scanning tools.. and v7.5 connected... now applied all beta updates and ready to connect again.
    Jul 2003
    ok same problem again... tried on a different laptop and it worked.. so something is conflicting with my pc on this update... previous version connects fine...
    Also.. .I cannot log, no matter what i do, to the PC the WB AFR data. Any tutorials would be great.
    Jul 2003
    well.. problem got fixed... DONT KNOW HOW! ... but oh well... it works on both lappies.
    Jul 2004
    Found a few more issues....
    - Compare gives me a access violation
    - did save as for an E40 and then loaded a E38 file and it didn't change the windows bar banner for name. In fact it overwrote my E40 with the E38 file on exit. Seems exit autosaves in some case even if you don't want to.
    - TCM speedo #'s on T42 look strange
    Will email you screen shots
    Quote Originally Posted by Highlander
    Even after you exit EFILive_Explorer, check to see if EFILive_Hapi is running in the system tray. If it is there will be a conflict between V7 and V8 software over the FlashScan USB device.
    Note: V7 and V8 are not meant to share access to the FlashScan devices. During beta testing it is necessary to handle the potential conlict manually by making sure Hapi is not running when you try to conenct to FlashScan with the V7 software.
    Quote Originally Posted by John Skiba
    Hi John,
    Please include the files you were working on and the steps required to reproduce the fault(s).
    Jul 2003
    the efilive hapi was not active at the moment. Don't worry... it was probably my PC as I got a hard disk failure and had to replace the drive... so I'm guessing it was some file on a bad cluster that got STUCK. Tried to reproduce the error on the other laptop w/o success.
  1. What have the issues been with LMM'S?
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 22nd, 2009, 01:06 PM
  2. A/C issues
    By Naf in forum Gen III V8 Specific
    Last Post: June 14th, 2009, 11:07 PM
  3. 2 bar E38 issues
    By XLR8NSS in forum E37, E38 & E67 PFI ECM's
    Last Post: May 1st, 2009, 02:51 AM
  4. KR log issues
    Last Post: October 3rd, 2008, 10:58 AM
  5. Still have IAC issues...
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: June 12th, 2008, 04:19 AM
